Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Brake Problem
Old Mar 23, 2008 | 08:40 PM
Jehuty's Avatar
Brake Problem
Well, I just got done changing my rotors to new ones drilled and slotted. now I am having a problem, because my brakes aren't very good at stopping anymore. I changed my pads, bled the brakes, but now the car doesn't stop as good as it did with the stock rotors, any ideas ppl?
Old Mar 24, 2008 | 05:20 AM
Kurt's Avatar
Did you properly break them in? I remember when I first put on my Brembo slotted rotors + Axis ultimate pads, my brakes were soft for about a week until they were totally broken in.
Old Mar 24, 2008 | 05:39 AM
I'm blue's Avatar
+1 properly break them in
Old Mar 24, 2008 | 09:25 AM
Jehuty's Avatar
So I guess mainly see how everything is by next week? I just get bothered by having to press them entirely down like I'm stepping on a clutch, rather than a brake. It just bothers me, the calipers were also just painted if that helps?
Old Mar 24, 2008 | 09:42 AM
Kurt's Avatar
Your peddle should not go all away to the floor. Just to be safe, bleed your brakes again. If that doesn't help, take it to a mechanic. The only way the paint would be a problem is if the paint got somewhere that it doesn't need to be.
Old Mar 24, 2008 | 09:46 AM
ambystom01's Avatar
You can always just bed them in faster. There's a how-to on here somewhere.
Old Mar 24, 2008 | 09:51 AM
Jehuty's Avatar
I've never heard of the term "bed" what does that mean?
Old Mar 24, 2008 | 10:01 AM
ambystom01's Avatar
Basically it means breaking the brake pads in and creating the layer that normally forms on the rotors.
Old Mar 24, 2008 | 01:31 PM
Hellvis's Avatar
The axxis ult. brake pads should come with a little piece of paper that explains how to break the pads in.
It something like this:
1. Find a long straight desert road.
2. Accelerate to approx. 50mph.
3. Deccelerate to approx. 30mph by hard braking(don't lock the wheels)
4. repeat step 2 and 3 AT LEAST 10 times(preferably 15 or more)
After that you should really feel an enormous improvement over your stock brakes.
If you still have a problem, then it can be many things.
1.You did not bleed the brake lines correctly.
2.You bought your rotors on Ebay, for a price too good to be true.
3.You bought your pads on Ebay, for a price too good to be true.
4. A combination of the above.
Old Mar 24, 2008 | 01:44 PM
ambystom01's Avatar
You won't feel the difference until the brakes have cooled, you essentially want to get them hot enough that they fade a little. I'll see if I can find the how-to I followed.
Old Mar 24, 2008 | 01:48 PM
ambystom01's Avatar
https://www.evolutionm.net/forums/sh...bedding+brakes
Old Mar 24, 2008 | 02:05 PM
Jehuty's Avatar
Well I have not heard anything bad from ebay rotors before, and I bought them a while back. If it helps at all, I drove a lot today and during the driving when I had to drive for long lengths, the brakes felt stronger. However, when I started driving again I guess they cooled down, so they felt like a clutch pedal again.
Old Mar 27, 2008 | 02:38 PM
mcgarvey's Avatar
If the pedal is going down like a clutch, you bled the brakes improperly and introduced air into the system. Driving the car in this state is extremely dangerous. You need to re-bleed the brakes, and I suggest you do it until clean, clear fluid flows from the bleeder. Buying a vacuum or pressure bleeder makes this very easy.
New pads do need to be broken in, but this should be done after a few normal stops. Most people will not even notice a difference before and after the pads are broken in. You definitely have a hydraulic problem.
Old Mar 27, 2008 | 07:43 PM
Jehuty's Avatar
Gah, thx guy, can someone tell me how to properly bleed brake lines, because I looked on here and all it is is some guy showing a custom way to bleed brake lines.
pckiller00
14
May 9, 2016 09:30 AM
Lucas03ES
Lancer Troubleshooting
Oct 24, 2007 07:32 PM
AzN_Enthusiast
Sep 2, 2007 09:41 PM
