Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Lancer 5-lug & Rear Disc Conversion Part List
Old Oct 22, 2010, 07:59 AM
  #91
mci2727's Avatar
^+1
I'm about to replace my master and would like to upgrade to either a evo 4 port if I can or use a 2 port with valve if I have to.
But I don't wanna do it and then not be able to drive it 'cause my brakes are locked down.
Also would love to see the pics link62.
Old Oct 22, 2010, 04:37 PM
  #92
link62's Avatar
The kit that i use is for es lancers only as we us mini cooper rotors that have a pattern of 4x100 for oz guys williepete metioned u can use the rear disk off a mirage, read back a few pages to see what he did for the front and rear
Heres my 3000gt master cylinder setup with the porportioning valve, couple of things to note is that u need to adjust the rod on the brake booster my making it shorter or ur brakes will be locked up and if ur 5 speed u will need to come up with a way to hold ur slave cylinder resivour and also i dont know how to wire up the sensor for the master cylinder since its different but i havent had any cel come on so oh well lol
heres the bracket from mirageman
and my old modified mirage one next to the new lancer bracket lol
everything bolted up
And heres my twin piston calipers
pad difference
caliper and rotor diffenece
the calipers came off a diamante, in the link below lets u know what other car have them, they have a screw in style line and our cars us a banjo line so i recommend getting the calipers with the banjo lines so u dont have to swap brake lines, and heres are the thread for the install how to and discussion of the rear and front kits
http://www.mirageforums.net/viewtopic.php?f=4&t=42786
http://www.mirageforums.net/viewtopic.php?f=13&t=42784
Old Oct 22, 2010, 10:27 PM
  #93
mci2727's Avatar
Looking good man, thanks.
Old Oct 23, 2010, 02:24 PM
  #94
89Mirageman's Avatar
Looks great man!
Old Oct 23, 2010, 10:53 PM
  #95
zulu989's Avatar
cant wait to do it, cost of my trans repair is the only thing holding me back :/
Old Oct 25, 2010, 07:53 AM
  #96
zulu989's Avatar
link put up a final side shot of thew car : )
Old Oct 28, 2010, 01:46 PM
  #97
mci2727's Avatar
I'm getting ready to replace my master cylinder.
Does anyone know how to tell if I have ABS brakes or not?
I do not have an ABS light in my cluster light up on startup or anything.
I am thinking I don't, but thet fact that they offer a master cylinder for ABS for 02 makes me want to find out for sure.
I would do the 3k gt upgrade but it seems a little over my head with adjusting the booster and all.
Old Oct 28, 2010, 02:50 PM
  #98
link62's Avatar
abs only came on the Ls lancers and if u do have it if u look at ur master cylinder u will have two ports instead of four
Old Oct 28, 2010, 04:34 PM
  #99
mci2727's Avatar
Good looking out man, thanks.
No ABS for me then.
Old Jan 10, 2011, 03:50 AM
  #100
Twitch377's Avatar
On to the front 5-lug conversion. The Ralliart and Lancer use the same spindle assembly, wheel bearing, etc.. You only need to change out the calipers and hub assemblies. The best route would be to source the entire spindle assembly from a Ralliart with the 5-lug hub already installed and maybe the caliper included. If not, here is the information:
Hub assembly (you need 2) - available new from Mitsu (MR519923), also may be ordered from a local part store
Calipers - available new from Mitsu (MR955063 & MR955064), or loaded from any local part store
Pete
can you get by with the stock calipers off the OZ Rally model and swap rotors obviously lol if your going from a 4 to a 5 lug assembly your going to have to swap out rotors please reply to my email at Twitch377@gmail.com
Thanks,
James
Old Oct 22, 2011, 08:25 PM
  #101
krisgoodwin84's Avatar
Does anyone know where you can get and the price is for the kit 89Mirageman was talking about. I sent him a message but he hasn't responded. Any help would be great thanks.
Old Oct 22, 2011, 09:56 PM
  #102
03lances's Avatar
Have you tried finding him on the mirage forums? Sounds like he is on those more than here.
Old Oct 23, 2011, 05:50 AM
  #103
Alchem1st's Avatar
^This. You'll have a lot easier time contacting him there than here.
Old Oct 23, 2011, 11:14 AM
  #104
Smile
Thanks guys Im pretty sure I found him on 4g61t.org last night. There actually a thread about him on that site talking about him and all the stuff he's sold people. Just waiting for a response.
Old Oct 23, 2011, 09:12 PM
  #105
hay if anyone wanted to know the kit with the brackets, ebrake adapters, hardware & brake pads from 89mirageman is $150 shipped
Quick Reply: Lancer 5-lug & Rear Disc Conversion Part List
