Problem on braking!
Problem on braking!
Hi everyone, I have an '05 Lancer ES that has something going on when I brake. At anything from moderate to heavy braking, I'm getting a bad vibration from the right front side of the car. Some mild vibration at highway speed between 65-75 mph, but not too bad. I rotated the tires, that seemed to help with the vibration at highway speed, but not with the vibration on braking. Wheels and tires have been rebalanced, no change. Everything seems to be in order. Any suggestions?
Thanks in advance for any help.
Kent
Kent
Some will say its pad buildup and some will say warpage.
Make sure you bed them in right. I trusted the stealer****'s word on that they bedded them in after they turned them. They warped again in ~1200 miles, and thats without any hard braking.
When I turned them again (just took the rotors to a place) and bedded mine in, I beat on them hard, and then let them cool for a good 10-15 min just cruising without using the brakes. I won't say the whole process because its sorta lengthy, just search bedding process.
Here, watch this on bedding process if you are going to get new pads / and or rotors.
http://www.essexparts.com/learning-c...rs/post/Bed-in
I bought my car in the states, Then I got shipped to Germany. After a couple of runs on the auotbahn, my rotors warp. I had the same problem. It was from high temp. and hard braking, causing the rotor to warp. I bought some EBC rotors and hawk pads. It got better now I think I need some new steel brake lines. There on order, i will get back to you to. To give the full set up.
orion4096
Feb 8, 2015 07:34 AM
MR White
14
Mar 3, 2013 10:21 AM
