need some help guys
need some help guys
can anyone tell me if the rear mirage toe arm will work with our cars.
I realize this has probably never been attempted before but since we dont have mirage cars here in canada I cant even check to compare.
I'm looking to use the megan racing mirage toe arms in my build if they will work.
I've read the mirage uses very similar suspension components to the lancer so I'm hoping they will work if I remove the grey arms sticking out of the bushing.
I also think I read of the mirage using the ralliart trailing arms for 5 lug disc so it might work..
toe arms in question below.
Thanks for any help guys. I'd like to get this nailed down as I have my camber arms on order from hardrace and should get my diff and axles in in the next 2 weeks. after that I should have the rear end buttoned up.. just need to figure out my toe are issue.
Cheers.
Cheers.
the eagle summit is the 93-96 chassis. I'm looking for the mirage chassis from 97-2001. this from what I've read shares similar suspension components with the cedia lancer chassis.
I'm building a rwd lancer and would like adjustable toe arms. I'm hoping I can use the megan racing toe arms built for the mirage.
I emailed megan racing but got nowhere.
SmokingTires
Jan 12, 2011 01:55 PM
