Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Suspension / Spring install
Old Jul 17, 2007 | 09:50 AM
  #31
Markley02's Avatar
2 questions.
If you have a spring compressor, why do you need an impact?
Can you just go to mitsu and by the evo camber bolt? It is an excentric (sp?) bolt that replaces the top bolt holding the strut to the steering knuckle.
Old Dec 24, 2011 | 09:09 AM
  #32
eusgen's Avatar
How do I remove the top 17mm nut from the bolt on top of the strut? Every time I turn the nut the bolt turns too, the whole strut cylinder turns with it so I can't even break it loose. I am loosing my mind.
Originally Posted by downsh!ft
i cant seem to get the front struts disassembled. the nut is inside that hole and you have to hold the threaded part still.. i'm having a hard time removing it with the tools i have.. anyone use something i'm not..
this is my problem
Old Dec 24, 2011 | 09:13 AM
  #33
CrAnSwIcK's Avatar
vise grips...clamp them on the piston shaft as far as you can as to not burr the metal where it would damage the oil seal during normal operation...then just crank it on with a ratchet or impact
or, you can use a crescent wrench and a normal open ended/box end wrench, where the top of the shaft is flat on two opposite sides, you put the adjustable wrench on that and just use a normal wrench on the nut...and do it by hand
as far as that quote goes, are you trying to remove the strut from the mount while it's still on the car? that's the problem right there, take the whole strut assembly out...it'll make life a lot easier...
Old Dec 24, 2011 | 10:07 AM
  #34
eusgen's Avatar
The entire strut assembly is out of the car, I just can't get the shaft to stop spinning.
I can't get a normal wrench on the nut because it sits inside the mount, it requires a deep socket to reach. I will take pics if I cant get it resolved.
Old Dec 24, 2011 | 10:43 AM
  #35
CrAnSwIcK's Avatar
oh, yeah, then vise grips...just clamp onto the shaft, and take the nut off. If you are re-using the strut, or when you install a new one, just push the dust boot up as high as you can and clamp there, so you're only damaging the metal where the strut will never travel, or you can go a step further and just use a scrap piece of rubber in the jaws of the vise grips if you're worried about messing anything up...
-Garrett
Old Dec 24, 2011 | 02:06 PM
  #36
eusgen's Avatar
Yea I still can't get a good enough grip on the shaft. Every time I try to hold onto the shaft with vice grips, pipe wrenches, strap wrench, etc. it just slips. I'm about to drill a hole into the shaft so I can stick something into it to hold it still.
Old Dec 24, 2011 | 03:54 PM
  #37
CrAnSwIcK's Avatar
use an impact on the nut, it'll come right off...
Old Dec 26, 2011 | 01:35 PM
  #38
eusgen's Avatar
used a 250 ft/lb torque impact and it came off
MitsuJoe
468
Feb 20, 2016 11:17 AM
Blacksheepdj
35
Jun 18, 2011 12:17 AM
urbanknight
Lancer How Tos / Installations
Dec 15, 2006 12:26 AM
vtluu
Jul 24, 2005 08:33 PM
MitsuJoe
Aug 1, 2004 01:59 PM
