Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
3rd Gear Rough Shifting
Old Jul 13, 2006 | 02:30 PM
BlueIrishs2k's Avatar
My 3rd gear has been getting harder and harder to shift into. I had the transmission fluid changed out (twice, actually) and it's still rough. I have a B&M short shifter and remember from the install that I had to put some lithium grease in the pivot sockets/cups. Should I just get some more and go crazy in there? Or could there be some other underlying issue? It only is rough shifting into 3rd.
Old Jul 14, 2006 | 10:17 AM
N1te's Avatar
Does it ever grind?
Old Jul 14, 2006 | 12:35 PM
Not really, though it could be a precursor to grinding.
Old Jul 14, 2006 | 07:39 PM
airlinevomitbag's Avatar
Check the fluid in you master cylinder. Maybe your slave puked some fluid and now there is air in the line and even though the clutch is on the floor it might not be pushing it out all the way and making it hard to shift.
Old Jul 16, 2006 | 06:17 PM
rcefstsfecr's Avatar
well i'm a rx7 guy at heart, but we have a 3rd gear syncro problem IDK???
is it smoother with a granny shift?
Old Jul 18, 2006 | 10:46 AM
Dunno about granny shifting it but I'm pretty sure (now) it isn't a gearbox issue. I worked through all the gears yesterday sitting at a light with the clutch in and they are all smooth as silk. Only when I am at speed am I having any problems and it is very slight now. Self-fixed I guess.
Old May 18, 2007 | 03:59 PM
Mirage2.0's Avatar
I have kind of the same problem.
At the stop there is no problem. While driving sometimes it's harder to put it into a gear than usual. Same thing with downshifting. No noise.
I check the master cylinder. What should I look for? Just fluid level?
BoostedAWD91
12
Jun 29, 2012 11:49 AM
ahr4156
12
Feb 21, 2012 06:57 PM
EvoIXPilot
Feb 16, 2012 11:49 AM
teamdomokun
16
Jun 30, 2011 09:02 AM
lightingyellow8
Apr 27, 2006 10:04 AM
