Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
act/clutchmasters install w/part numbers
Old Jun 4, 2007 | 07:33 AM
Mirage2.0's Avatar
Anybody?
Old Jun 4, 2007 | 11:21 AM
ambystom01's Avatar
I think the 4G93 clutch works but the throw-out bearing does not.
Old Jun 4, 2007 | 12:47 PM
Mirage2.0's Avatar
Thanks, but I have to be sure.
Old Jun 4, 2007 | 12:52 PM
ambystom01's Avatar
Check out the mirage-lancer compatibility forum, I'm sure it says in there.
Old Jun 4, 2007 | 01:45 PM
Mirage2.0's Avatar
thanks.
Old Jun 5, 2007 | 06:27 AM
Mirage2.0's Avatar
Which clutch is the strongest? In order:
HD00, HDSS, or 6 pad clutch (all with heavy duty pressure plate)
Thanks.
Old Jun 5, 2007 | 10:07 AM
ambystom01's Avatar
I would guess 6 pad clutch, HDSS and then HD00, at least if I'm remembering the website correctly. I personally would not go with the 6 pad clutch, it's not meant for street use or at least not for daily driven street use.
Old Jun 6, 2007 | 01:24 AM
petey pab's Avatar
yes, 93 clutches work fine. you just have to pick up a stock TOB from the dealership or here... https://www.mitsubishiparts.com/oe_parts_catalog.html for a much cheaper price. i currently have the ACT heavy duty pressure plate with 6 pad disk. not so harsh engagement but kind of the on/off effect.
Old Jun 6, 2007 | 05:53 AM
Mirage2.0's Avatar
^Thanks, so like the guy told me, just get 6 puck.
Old Jun 6, 2007 | 05:57 AM
Mirage2.0's Avatar
On mitsubishiparts.com it's called Release bearing?
Old Jun 6, 2007 | 06:25 AM
Mirage2.0's Avatar
Which one do you have? HDR6 or HDG6? Sprung or Unsprung?
And what do you mean on/off effect?
Sorry for alot of questions, lol.
Old Jun 6, 2007 | 10:37 AM
ambystom01's Avatar
Like I said, I wouldn't go with a 6 puck clutch. Try to match the clutch to your power output. On ACT's site they don't recommend going with the race clutches unless you need them. While I understand the urge to get the "best" clutch you can, you'll just pay for it in driveability.
Old Jun 6, 2007 | 05:57 PM
petey pab's Avatar
yes it is called release bearing as well. i believe it will be around $100 or so.
i believe i have the HDR6. ive never heard of the sprung or unsprung setups, but i dont think they make them for our car.
and by on/off, i mean there really isnt any play when youre engaging and releasing the clutch. the clutch is basically fully engaged within the first two inches of pressing in the pedal. it goes from engaged to disengaged without any leeway. its not as bad as it sounds but its kinda hard to explain. hope it helps.
Old Jun 6, 2007 | 07:17 PM
Mirage2.0's Avatar
I just ordered HDSS. Still should be good enough.
Randal
Nov 28, 2012 07:34 AM
EGbeater
Oct 18, 2011 12:58 PM
Pal215
May 17, 2011 10:53 PM
evascst
Feb 3, 2010 10:19 AM
delkat
Feb 3, 2010 07:33 AM
