Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
trying to replace transmission filter in my 03 lancer ES
Old Nov 17, 2007 | 09:41 AM
samer's Avatar
Hi Guys, So i am trying to change the transmission fluid in my 03 Lancer ES, i went to the store and bought the filter (looks just like an oil filter) and bought 8 quarts of transmission oil. I found the drain plug for the transmission oil, but i cant find where the transmission filter is!
Any one have any idea, i tried doing a search for this but came up with nothing. Thanks for your help ahead of time guys!
Old Nov 18, 2007 | 06:41 PM
autobahn3000's Avatar
U have an automatic right?
if yes the filter is internal. You have to buy a new gasket for the transmission pan. so U drain all the tranny fluid and drop tranny pan and the filter will be inside. remove old filter and install new filter. clean the pan out and there should be a magnet inside the pan make sure to clean that also. any gasket material on pan should also be cleaned off to insure a good seal with the new gasket (do not scratch the sealing surface's!!!) also make sure before U drain the tranny fluid get your car up to operating temp before starting.
Old Jan 30, 2008 | 08:04 PM
porterj5's Avatar
Does any one have any pics of the how to replace the filter? I can not seem to find any info in the manual on CD I bought
Old Feb 13, 2008 | 05:54 PM
crazykamper's Avatar
what kind of tranny fluid are you using???? i need to re-fill mine after replacing axel. would like to know asap, thanks!
any pics of how you drain/fill it?? thanks!
Old Feb 14, 2008 | 05:48 PM
SLVROZ_03's Avatar
Use Mitsu ATF III available @ the dealership of course. And sorry to tell you, but all auto store computers list the incorrect trans filter. The trans filter is a thinner, narrow pan-like filter...not a circular screw-on one. I tried finding a pic for reference, but of course I can't remember the site. But all the items can be found at the dealership or online too.
Old Mar 2, 2008 | 10:19 AM
MA70_NA-T's Avatar
BUMP, Does anybody know which line is it to disconnect to flush the automatic transmission fluid? Looking from the drivers point of view , which line is it, the left or the right one? any help is appreciated
Old Mar 4, 2008 | 06:56 AM
kenshinx001's Avatar
i thought we have a sticky in the how-to section? i swear i saw it like 4 yrs ago, and that's how i did my transmission flush in my auto. the filter is a bi$$$. you need to remove like 16 screws to gt to the filter. gl getting the info, looks like they remove that sticky
ummm here's an old thread:
https://www.evolutionm.net/forums/sh...ad.php?t=84977
Old Mar 4, 2008 | 01:54 PM
SLVROZ_03's Avatar
There is a drain bolt behind the driver's side wheel! I believe it's a 21mm?
Old May 6, 2008 | 11:57 AM
Jehuty's Avatar
Geez, we need pictures because my tranny is messing up and now I think I know why. I had my fluid changed at Tire King. and I think they put the wrong fluid
Old Mar 26, 2016 | 06:30 PM
kingtrix's Avatar
where does the external ATFilter go i know the internal goes inside
did you ever end up finding out how 2 change the external?
i have both filters but idk where the external goes.. so confused
Old Mar 26, 2016 | 08:06 PM
jimbo74's Avatar
Veteran: Air Force
there isn't an external filter
Old Feb 25, 2017 | 06:13 PM
Jamal Arurang's Avatar
I have a Mitsubishi lancer 2003 ES and im Wondering if someone can tell me what type of oil I need for my transmission( specific and the most up to date version).
What kind of flush should I get for the trans? Asap????
Old Feb 25, 2017 | 10:47 PM
CrAnSwIcK's Avatar
DIAMOND ATF SP III is OEM fluid, and is recommended...an SP III equivalent will be better than nothing if your oil is really bad...
09RASST
Aug 1, 2020 09:03 PM
Tom Teeny
Lancer Troubleshooting
Feb 20, 2018 06:14 PM
codeman911x2
Apr 25, 2017 02:18 AM
wesleylawson6
Lancer Engine Tech
Mar 30, 2016 08:02 PM
aviseevuoptical
Feb 28, 2016 12:24 PM
