Changin the fluid for AT
can someone show me where the drain plugs are or whatever it is cuz i read it in the how to but without pics im so lost... please help me some1 before my tranny goes to s*** more than it is...thanks a lot guys n some of da girls id appreciate it
to change the fluid on the auto tranny it is a *****. i suggest you take it to AAMCO or whom ever and pay the 150 bucks cause if you just change the fluid, you aint doin any good. you need to change the fluid and filter (or clean the screen) cause that is the best way to maintain your tranny.
do do that you need to drop the pan on the tranny and pull out the filter. can be done but it is a PITA.
Our transmissions have an internal filter that only needs to be changed every 100k miles. You can't get to it without tearing the thing apart. I find this out AFTER I order the stupid filter. What the Mitsu dealership said was to have the fluid flushed every 30k miles. Its not like a conventional transmission.
that filter that should only be changed every 100K should still be ideally replaced every 2 tranny fluid changes, 60K miles would be ideal, for a car under heavy duty.,
Remember all dealer quoted maintenance time frames are for stock, mediumly driven cars.
Take a good look at the trans. There is no pan on the bottom of it. What you would consider the pan is on the front side of the trans, and without pulling the trans, that simply isn't going to happen. None of us can afford to have than done every 60k. I don't know what mitsu was thinking when they designed it, but it is deffinately not built like regular transmissions. The filter doesn't even look like a normal filter. I'm going to have to take the service guys at their word that it doesn't need changing, and that I should just have the fluid flushed out, which I had done last night. IF you can find a easy way to get to the filter, please share. I would do it if I could.
actually it isnt that uncommon for the pan to be on the side.
this tranny is used in mirages and some eclipse (slightly different form of the F4a42).
I had the filter replaced and all the fluid done at 30K for 259 from my local tranny shop.
any pics of what a tranny filter / gasket looks like. for months i was looking for it and now that i bought it i wanna make sure it's the right filter. And if possible can someone show me the location of filler and drain plug? I only saw the manual one. And about what raven said it doesn't even look like a filter just flush it. So I wanna make sure I got the right filter.
their is that page that has the oil breakdown for a mt, but they posted the thing from the service manual on how to do both. you can do it by yourself. its not hard. just make sure you buy a little extra oil so you can add oil as you drain it, until you get only new oil draining. then stop and filler up. check guage to make sure its full, start it, run it for a bit, go for a short drive, whatever, then stop the car and check the line again, if its still normal, should be near the hot on the thing or somehting, i forgot, but buy redline, hear alot of great things from the mt guys. and i emailed the guy last night about which of the two for at's to buy, and how much it would be all together. but we need like 7.7, so 8 quarts, at 7.86 or 7.96 a quart. so about $56 and then shipping. so not as bad as $200 something at a shop. if its your 30k change, dont worry about filter and gasket, unless you dog your trans and car. wait till about 60k or 100k to check it out. dont fix it if it aint broke.
WTB[MidWest]: WTB: stock recaros
RedEvoxGSR
Jun 8, 2016 12:31 PM
[WTB] Evo X OEM Tail lights
mcsteezy
May 30, 2016 01:06 PM
escodotcarter
Aug 31, 2004 07:31 PM
