Would an 05 Lancer tranny fit in an 02??
Subscribe
Mar 10, 2008 | 06:06 PM
Does anybody know if an 05 trans would fit on an 02 lancer oz? thanks guys
Reply 0
Mar 10, 2008 | 06:20 PM
Assuming they're both from a 4G94, then yes.
Reply 0
Mar 10, 2008 | 06:27 PM
alright, are you guys sure, it would make sense but before we go to buy it i want to be sure it will fit correctly
Reply 0
Mar 10, 2008 | 06:58 PM
maybe call mitsu and ask them?! Most wreckers will know this info as well.
Reply 0
Mar 10, 2008 | 07:33 PM
ok, well the junk yard said it wouldnt fit but i thought ide check. maybe ill call mitsu
Reply 0
Mar 10, 2008 | 08:14 PM
Don't see why not since it's the same car. All that changed was the fuel system and that has nothing to do with the transmission.
Next time, wait, don't post the same thread twice.
Reply 0
Mar 10, 2008 | 11:14 PM
Check the transmission code/partnumber of both cars and if it matches your good. If not, call mitsu with the part number and get them to list you the cross-referanced numbers and if one of those match your good. Otherwise no.
Reply 0
Mar 11, 2008 | 05:07 AM
Quote: i posted this in the tranny section but it doesnt get much attention so i gotta post it here. so, anybody know if an 05 trans would fit on an 02 lancer oz? thanks guys
It would fit, you will need a little more parts than just the tranny... The 04-06 tranny use the mirage style clutch fork, cylinder actuator and throuth out bearing... Mitsubishi return at the old style desing if I remember exactly.
Or just switch the belt housing...
Reply 0
Mar 25, 2008 | 09:57 AM
what about an automatic trans.?
would that match up?
Reply 0
Mar 25, 2008 | 02:49 PM
Moving this to the right lancer section.
Reply 0
Subscribe
