Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
speed sensor issue after 5spd swap
Old Dec 12, 2008 | 05:54 PM
senate6268's Avatar
Originally Posted by vt-sky
sigh no go on the connection senate
Are the wire colors I listed above correct or different?
Old Dec 14, 2008 | 12:12 PM
vt-sky's Avatar
correct
Old Dec 14, 2008 | 12:16 PM
vt-sky's Avatar
oh u only mention 2 wire but there 3 wire on the connector of the speed sensor..i figure it a ground cuz it solid black unless if for sumthing else
Old Dec 14, 2008 | 12:52 PM
senate6268's Avatar
Ok. Here's what the FSM shows. On the auto trans output speed sensor that black wire goes to the PCM. However, on a manual trans that wire is grounded and does not go to the ECU. If you ground this wire you should be up and running. Give that a try.
Old Dec 16, 2008 | 12:11 PM
vt-sky's Avatar
alrdy did ground it... dat wat it thought it was
Old Dec 16, 2008 | 07:59 PM
senate6268's Avatar
Ok. Digging through the circuit diagrams I came across what looks to be a difference in wiring on the harness for an auto vs. manual. If you look in the red box you will see that the input wire is on different harnesses. Did you swap the PCM out for an ECU?
Attached Thumbnails speed sensor issue after 5spd swap-tach.input.cluster.jpg
Old Dec 19, 2008 | 12:46 AM
vt-sky's Avatar
nope im still using the auto ecu
Old Dec 19, 2008 | 12:04 PM
senate6268's Avatar
Ok. It now makes sense. Your PCM is currently sending its vehicle speed signal to the cluster as it should. However, its not receiving a speed signal to send because the output speed sensor no longer exists. So the vehicle speed sensor is sending a signal to the PCM which does not know how to interpret it. You need to switch to an ECU and then switch the pin on the harness for the vehicle speed sensor signal to be interpreted and passed on to the cluster. Swapping the PCM out for an ECU is necessity when performing a 5-speed trans swap.
Old Dec 19, 2008 | 12:56 PM
vt-sky's Avatar
hahahha guess i go on without a speedometer but everything else is fine from the swap...been a year without it
LSs1Power
May 27, 2017 09:17 AM
DRAG
Evo X How Tos / Installations
14
Jul 1, 2009 01:23 PM
EgoBstr
May 19, 2008 03:01 PM
deadblindclown
Mar 10, 2006 03:59 PM
NocturnalEVO
Sep 14, 2004 10:12 PM
