Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Loud noise
Old Jul 17, 2008 | 05:10 AM
evo323's Avatar
^what he said.
Old Jul 20, 2008 | 08:42 PM
mrpeeper's Avatar
input shaft bearing is shot. how hard is it to change and what clutch u guys suggest for stock
Old Jul 20, 2008 | 09:15 PM
LancerPride's Avatar
DELETE DIDNT SEE YOU FOUND THE PROBLEM
i just saw what you said INput bearing was the same problem for me
Old Jul 20, 2008 | 09:19 PM
mrpeeper's Avatar
where did u get the new bearing?
Old Jul 20, 2008 | 09:21 PM
i had it done at the shop only cost me 808 with new Clutch Stage 2 and new TOB and input bearing
if you want i can get the info from the shop owner to see where he got input bearing
Old Jul 20, 2008 | 09:25 PM
mrpeeper's Avatar
yeah that would be really sick i can do it myself i just cant find the seal and bearing anywhere. and did he say what caused it to go bad?
Old Jul 20, 2008 | 09:28 PM
Alright i will tomorrow hes off for the night so i let you know
and he didnt tell me why it went out but due to the car having 112k on it that might be the reason
Old Jul 20, 2008 | 09:30 PM
mrpeeper's Avatar
yea wow mine when out at 115k 5 k after my new clutch so now i gotta get a new one cause gear oil got all over everything. im pretty sure all i gotta do is remove the bell housing and the bearings on the inside of it
Old Jul 20, 2008 | 09:51 PM
yep same thing my clutch went out after i had it replaced over 1 month ago due to input bearing
Old Jul 23, 2008 | 10:34 PM
SlvrOz's Avatar
I had the same problem with my OZ, every time that i engage the clutch it would make a weird noise and it turned out to be the throw out bearing.
Old Jul 24, 2008 | 01:57 PM
mcgarvey's Avatar
Just FYI, a noise with clutch pedal in is the TOB.
A noise while in gear or netural with the clutch pedal up is the Input Shaft Bearing.
Old Jul 27, 2008 | 11:23 AM
mrpeeper's Avatar
i got the parts but i can get the bellhousing off anyone know how?
Old Jul 28, 2008 | 04:19 AM
mcgarvey's Avatar
You have to remove the extension housing, remove the 5th gear shift fork, pull the 5th gear synchro assembly and 5th gear off using a gear puller. Remove the axle nut looking thing using a holding tool and breaker bar (not an impact gun). Then you can separate the transaxle case from the bell housing. The main shaft if i remember is held with a snap ring behind the input bearing.
Replace and reassemble. Use only Anaerobic sealant to reseal the case, never RTV! I believe Loctite 518 is preferred.
Good luck!
captinnitro
Feb 24, 2016 10:03 AM
P0411
Jul 15, 2015 11:48 AM
SilentEvo8
Aug 22, 2014 01:10 PM
ZensokuEVo
Dec 19, 2011 10:23 AM
rartist
Aug 11, 2010 06:21 AM
