Shifter linkage
Shifter linkage
There are two links going from the shifter toward the front of the car.
Does any body know which gears those those two linkages control? Is it the first link works 1st and 2nd and the other linkage works the rest of the gears? Or maybe 1st thru 3rd for one, and 4th,5th,R, for the other etc...etc...?
Its Seems there's no info on this as far as i can find
None of the above. One controls the left/right movement as articulated by the shifter, and the other does the up/down. Have someone move the shifter while you watch under the hood and you'll see.
So you are saying the Mitsu factory service manual is wrong?
I assume the small cable (select cable as it's called by Mitsu) moves up/down to select the gears in that position. And the big cable (shift cable) moves to the different positions (1,2), (3,4), (5, R).
What you're saying is exactly the same as what I said. The big cable does the left/right, and the small does the up/down. Just have someone sit in the car and play with the shifter while you watch the cable ends and you'll see how it works in like two seconds.
lmfao, I meant the shifter linkage. Look at my thread called "worst problem EVER!!!" because I am having trouble with my tranny
