Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Slave cylinder swap
Old Jun 14, 2009 | 11:08 AM
imalancerman's Avatar
Slave cylinder swap
Whats up guys? I just bought a stage three clutch for a mirage and Ive been told the throwout bearing only works with 04 up which I knew at the time of buying. I was curious if its possible to swap the slave cylinder and shifting fork from the 04 up onto my 02 transmission? I would like to do this for several reasons, one being it would be easier and cheaper to replace the throwout bearing. Two, because I dont have 140 bucks to replace my current throwout bearing. I dont know how smart it would be to reuse my old one as it has 140k on it, which doesnt seem like a bright idea to reuse. I just want to know if the 02 transmission has all the same mounts as the 04 up so that I could get a slave cylinder and shift fork or if Im up $hit creek for this? Thanks to all.
Old Jun 14, 2009 | 11:56 AM
senate6268's Avatar
Yes you can swap your slave cylinder over to the 04+ external style. I've got all the parts laying around to do this when I get my transmission back from rebuild.
Old Jun 14, 2009 | 01:18 PM
What are all the parts necessary to do this and will mirage parts work cause I know the 4g93 tranny is supposed to be the exact same housing and the slave cylinders look identical and I can pick those parts up for alot cheaper.
Old Jun 14, 2009 | 02:20 PM
senate6268's Avatar
MD747524 Clutch fork Mirage = yes
MD747413 Boot Mirage = yes
MD719602 Fulcrum Mirage = yes
MD747279 Bearing retainer Mirage = yes
MF140203 Bolt (x4) Mirage = yes
MD749998 Throwout bearing Mirage = yes
MD748038 Clutch line Mirage = no
MR980563 Slave cylinder kit Mirage = yes
MF241255 Bolt (x2) Mirage = yes
MD706185 Throwout bearing clip Mirage = yes
So as you can see, with the exception of the clutch line that goes to the slave cylinder everything is compatible with parts from the 1.8L Mirage
Old Jun 14, 2009 | 10:27 PM
Oh wow. Thank you senate. I dont often get information that is this detailed. I appreciate that you do your homework. Thank you again.
Old Jun 15, 2009 | 04:35 PM
senate6268's Avatar
Took me like 5 minutes to select all the parts in MitsuCAPS in my XP VM and copy them into the post, but you're welcome anyway.
Old Jun 15, 2009 | 05:31 PM
How much did you spend for all your parts for this swap?
Old Jun 15, 2009 | 06:07 PM
*02Lancer*'s Avatar
How much do all those cost the the throw out and slave are the same part for the 02. And was like 120 from dealer. Was all those parts cheaper?
Old Jun 15, 2009 | 06:35 PM
My dealer wants 140 for an oem. I dont even care if it costs more. It saves you a ton of money in the long run but just curious since I dont have much cash. Ill probably end up putting my old one back in till I can save the money up and hope it doesnt go out
Squidd
Jul 31, 2017 07:27 AM
MitsuJoe
468
Feb 20, 2016 11:17 AM
Keefxn180
Oct 29, 2015 11:11 AM
yitzac1990
10
Jul 20, 2015 09:38 PM
lancer758
Jul 21, 2010 12:02 PM
