Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
03 OZ throw out bearing / transmission issue
Old Oct 22, 2010, 06:58 AM
captainobvious's Avatar
Arrow 03 OZ throw out bearing / transmission issue
My 2003 Lancer OZ has about 155K miles on it.
I've never had any issues with her outside of one replaced brake
rotor. These cars are solid
That said, over the course of the last month I've been hearing a noise
that has been slowly getting worse. Its a rattling/grinding sound coming from the transmission area. I hear it whether moving or idle, unless I push in the clutch...then it quiets down. A friend of mine suggested it could be the throw out bearing. My clutch itself has never slipped or popped out, still goes strong.
My questions are:
1. Do you agree that the issue is likely the throw out bearing?
2. Can this be replaced without replacing the clutch?
3. Does it make sense to NOT replace the clutch at this point? ($$)
4. What should I expect to pay from a dealer/private shop for this service?
I asked a local garage for a price on replacing the clutch and they gave me $1300 for a SOHC 2.0 and $1600 for the DOHC 2.0. Unsure why one would cost more than the other...? Oh, and that seems pretty expensive, no?
Thanks !
Old Oct 22, 2010, 07:18 AM
eusgen's Avatar
Replace the clutch, master, and slave cylinders and get the flywheel resurfaced or replaced if it is too worn. Parts total will run about 700 dollars and labor anywhere in the same play field. Make sure that someones estimate includes everything I stated above or they are just blowing smoke.
Old Oct 22, 2010, 07:27 AM
mci2727's Avatar
Sounds like the throw out bearing.
It's connected to the slave cylinder, so you replace that too.
As stsated above, you should replace clutch, TOB, input shaft bearing, master cylinder and flywheel resurface.
It's time man.
And don't wait, it can mess your trans up bad.
Old Oct 22, 2010, 10:10 AM
How about the difference in price between a sohc and dohc? Arent they using the same transmission parts/clutch?
Thanks for the quick responses all, much appreciated.
Old Oct 22, 2010, 10:15 AM
mci2727's Avatar
Nope, different parts.
The Lancer 03 never came in a dohc version.
He's prob. talking about the difference between an Evo and Lancer.
Old Oct 22, 2010, 11:07 AM
Ahhh, ok. Thanks.
Old Sep 19, 2018, 01:21 PM
afahl's Avatar
Same issue
I am having the same issue but in my case i have had the clutch replaced and the slave cylinder about 12 months ago. Would i have to replace everything again or just the throw out bearing?
k0lok0yboi
Jun 11, 2016 03:40 AM
mci2727
24
Feb 12, 2016 11:11 AM
gonzo6150
66
Jan 14, 2013 10:28 PM
MitsuJDM
44
Dec 18, 2012 06:48 AM
SnowWhite
11
Apr 6, 2011 11:49 PM
Quick Reply: 03 OZ throw out bearing / transmission issue
