Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
need some help ASAP!! SS clutch lines?
Old Dec 8, 2010 | 08:27 AM
yitzac1990's Avatar
Are there any companies that make stainless steel braided clutch lines for the lancer? I think one of my lines blew out and now I need to get a replacement, might as well upgrade....
Thanks!
Old Dec 8, 2010 | 01:47 PM
nj_08_gts's Avatar
Could always make your own. How do you think the clutch line blew?...should be pretty obvious if it did.
Old Dec 8, 2010 | 09:44 PM
yitzac1990's Avatar
hard to tell, it was driving fine all day, then i get back in it to go home, push the clutch in, and it just drops. look under car, puddle of clutch fluid, but its directly under the tranny, not where the hard line goes into the tranny in front, so i dont know. felt around the line from the firewall, down the first soft line, all the way down the hard line, no wetness. couldnt see any wetness anywhere, but i havent jacked up the car yet. apparently we have an internal slave cylinder though?
Old Dec 8, 2010 | 10:13 PM
nj_08_gts's Avatar
You may just be leaking. Have you done clutch work fairly recently? Start cheap and easy...look for loose fittings before you look to replace parts.
Old Dec 8, 2010 | 11:07 PM
yitzac1990's Avatar
haha yeah man, i have a stage 3 ACT clutch with heavy duty pressure plate....
Old Dec 9, 2010 | 07:27 AM
nj_08_gts's Avatar
Any extra parts when you finished installing it?
Old Dec 9, 2010 | 08:40 AM
yitzac1990's Avatar
lol i had a shop do this one, but no, no extra parts. its been on there for a whole year already with no problems....
Old Dec 9, 2010 | 11:45 AM
M@verik's Avatar
It could be that the cylinder burst. Or even might be a seal. No way to tell exactly until u jack the car up and check.
Old Dec 9, 2010 | 08:09 PM
yitzac1990's Avatar
yeah a friend and i jacked the car up and looked and he saw fluid dripping from a small hole at the bottom of the tranny, so we determined that the slave cylinder is in fact internal and that it has burst or a seal went bad or something. next week we are removing the tranny and inspecting further.
Old Dec 12, 2010 | 12:56 AM
M@verik's Avatar
If it is a seal I might be able to help u as my company manufactures seals and cylinders. Will just need measurements to check if we have any seals that fit. Otherwise no slave cylinder developed yet.
Old Dec 12, 2010 | 10:27 AM
yitzac1990's Avatar
nice, but i dont think the cylinder is repairable lol
Old Dec 12, 2010 | 11:26 AM
M@verik's Avatar
Ah is it one of those plastic ones? If so you are correct.
Old Dec 13, 2010 | 11:39 AM
yitzac1990's Avatar
well the slave cylinder and throwout bearing are all one unit, not sure of the material.
evoVIImoneypit
May 5, 2017 08:38 PM
akunochi
Nov 14, 2005 12:54 PM
Boston'sEvO-->8
Sep 22, 2005 07:01 AM
exhaust_note
Aug 11, 2005 09:44 PM
TheBigLubinsky
33
Feb 3, 2004 06:59 PM
