Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
AWD conversion info thread
Old Aug 25, 2011 | 03:54 AM
Alchem1st's Avatar
Who has looked into it? I don't have a newer Lancer, but a friend has a GTS and we've been talking about converting it to AWD. Now before I sound like I'm asking a newb question, let me say I've researched this a bit and it seems like it wouldn't be a difficult conversion. Rear subframes and trailing arms have the same part numbers between the CY5A (GTS, ES, and DE) and CY4A (Ralliart) according to ASA. (though I don't trust it as they don't have the Ralliart listed as being awd ) It looks like all there is to the rear end may be getting Ralliart wheel bearings and axles and buying a rear diff assembly. What I need to keep this research up is lots of pics of the DE,ES,GTS rear subframe and suspension bits and also lots of pics of the Ralliart rear setup for comparison as all I have at the moment is what's posted below. The other bit I don't know about is what would be involved in swapping to the Ralliart tranny and whether the RA driveshaft will work out of the box or need modified; but let's figure this out a piece at a time starting with the hard part (that being the rear end assembly) LOL. If someone else has already discussed this in detail then sorry, I did search. Let me also add that from what I can tell these cars will be much easier to convert down the road than the older Lancers and Mirages. I'm currently working on converting a Mirage to an Evo IV and I actually will be cutting out the Mirage floorpan and welding in an Evo one in it's place. I don't think it will be near as hard to convert this generation Lancer with it's bolt in subframe design vs the old Lancer/Mirage welded on crossmember setup. Thank you Mitsu for making it easy on us for once! (Maybe? )
Here are some pics of the Ralliart and Evo X rear subframes and how the diff bolts in:
Ralliart:
Evo X:
How it goes together: (This is an Evo X setup; note the diff only sits in the one mount in the back and also note where the diff wings bolt too)
Old Aug 25, 2011 | 04:34 PM
a.w.o.l's Avatar
nice....keep us updated on ur findings..
Old Aug 25, 2011 | 04:37 PM
Alchem1st's Avatar
Will do, but I need you guys help for pics as I don't have a Lancer to reference.
Old Aug 26, 2011 | 08:16 PM
a.w.o.l's Avatar
not a problem...just tell me what pics u want..
Old Aug 26, 2011 | 09:27 PM
Alchem1st's Avatar
I need pics of the rear subframe to verify that the single rear mount is there (lower circle) and that the forward mounts are there (upper circles) and also in inside of the trailing arms where the axles would go through. Also of the fuel tank tunnel where the driveshaft would be to make sure there's room for it. Also need to know if the spots for the driveshaft hangers are there. (the hanger brackets may even already be there, they are on the Mirage) It looks like AWD will be very easy for you guys!!!
This is what you need to look for on the subframe:
Old Aug 27, 2011 | 08:02 PM
a.w.o.l's Avatar
ok...will do...i'll try to take them tmrw jus hav a few tings to do 1st..
Old Aug 28, 2011 | 09:52 AM
Mex24x's Avatar
LoL I'm glad to see this thread cause I was about to convert my FWD GTS to AWD and add a turbo. Cause of the RRM Lancer Video I saw but unfortunately my GTS got totaled by an 18 wheeler?
No worries I got a truck has a replacement for two months n in November-December I'm getting my EVO X GSR
Old Sep 7, 2011 | 08:04 AM
EvansEvoSOUL's Avatar
Front wheel is the way to stay because you'll catch an evolution if you get the same horse
Old Sep 7, 2011 | 12:06 PM
Alchem1st's Avatar
True true, but AWD is more fun in the Winter!
Old Sep 10, 2011 | 08:25 PM
neverendingmods's Avatar
Just buy an EVO. Or, best thing to do is buy a wrecked EVO and swap drivetrain, main harness into Lancer. Remember that the EVO tans has a computer controlled center diff and all that would need to be added. You're looking at a $10k swap to add the drivetrain, axles, hubs, harness, brakes etc. Makes more sense to just buy a wrecked evo and swap all the parts over to the lancer.
Old Sep 10, 2011 | 08:45 PM
Alchem1st's Avatar
I think you missed the point. I'm not planning to convert a Lancer, in fact I don't even own one lol. I've just been looking into what it takes to do the conversion for people who may want too in the future when its more cost effective. If us mirage guys knew 5 years ago how easy it actually is to convert our cars to awd there'd be a whole lot more swapped ones on the road. Sofar it seems like the conversion wont be super hard parts wise and I'm sure the electronics will eventually be figured out. Gotta start somewhere heh.
Old Sep 11, 2011 | 03:05 PM
Rog96's Avatar
hey alchem1st u can use my car for any pics needed u know that lol
Old Sep 11, 2011 | 05:47 PM
Alchem1st's Avatar
Haha yeah, we need to hang out again soon. If nothing else, MOD.
Old Sep 11, 2011 | 05:54 PM
Rog96's Avatar
ya will do but i wonder if anyone is doing this and if so id like info cuz im becomng very fond of my sportback
Old Sep 11, 2011 | 05:57 PM
Alchem1st's Avatar
Haha half the guys here will tell you it's cheaper to buy a RA or a X. I'm up for it though if you want to!
