Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Clutch
Old Nov 18, 2011 | 10:52 AM
Seifer780's Avatar
Clutch
This is going to sound extremely silly, but I am under the possibly false impression that when I bleed my brakes, I am also bleeding the fluid that operates the hydraulic clutch. Is this correct, or false?
I'm honestly not sure.
*hides behind a door, avoiding imminent tomato throwing*
Old Nov 18, 2011 | 10:58 AM
burner67's Avatar
we have something like a double reservoir. but the clutch fluid should remain fine even tho you are doing the brakes. yes its the same fluid and all but the brake fluid will run out before the clutch will because its drained from a higher position or something. just investigate the reservoir and you'll figure out what i mean
Old Nov 18, 2011 | 06:11 PM
CrAnSwIcK's Avatar
same reservoir, different lines/system they are bled independently, and the procedure is quite different...DO NOT PUMP THE CLUTCH PEDAL FOR PRESSURE!!
Moussa93
For Sale - Cars For Sale
Apr 25, 2016 01:15 PM
h4ckluserr
Aug 22, 2011 11:21 AM
GBEvo
27
Nov 14, 2009 06:40 PM
MR. EVO MR
Oct 31, 2009 02:11 AM
ImportUpgrade
For Sale - Part Outs
75
Feb 7, 2007 10:45 AM
