Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Cracked transmission cooler (CVT)
Old May 24, 2012 | 02:51 AM
Heebs 09gts's Avatar
I hit something and cracked the cooler. Long story short...
Started the car, backed out of driveway, the cooler dragged and broke and pissed out all the CVT fluid, i immediately pulled in the drive way and turned off the car, and fixed my problem.
My question is, would literally 10 seconds being low on fluid damage the transmission in any way?
Old May 24, 2012 | 03:01 AM
SaulHudson's Avatar
You didn't pull the magnetic drain plug when you refilled the trans? That would be you way to tell weather it was damaged. It if had lots of medium to large metal shavings, that would be bad. A small amount of very fine shavings is normal.
Old May 24, 2012 | 12:19 PM
No i didn't, I will have to check that out. Thanks for the help!
Old Jun 11, 2012 | 08:13 AM
Rahtid's Avatar
you didnt do any damage, replace the cooler and oil
Old Jul 15, 2012 | 12:15 AM
Good to know. CVT still running strong!
Ghilversumtuner
23
Apr 11, 2019 09:28 PM
Bow87
Aug 31, 2017 09:47 AM
pcguru2000
Apr 7, 2017 02:42 PM
lancer se04
Oct 6, 2012 03:37 PM
kmc8302
Lancer Engine Tech
Dec 18, 2009 01:51 AM
