Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
NO pilot bearing?
Old Jul 29, 2015 | 10:15 AM
jimbo74's Avatar
Veteran: Air Force
NO pilot bearing?
I just want to confirm that the F5M42 does NOT have a pilot bearing
Old Jul 29, 2015 | 02:29 PM
jakermeister's Avatar
The 02-03 has it built in with the internal slave. Only the 04-07 lancers have a separate throw out bearing (pilot).
Old Jul 30, 2015 | 09:56 AM
CrAnSwIcK's Avatar
the TOB (clutch release bearing) and the pilot bearing are two different things...the pilot bearing or bushing simply ensures the the transmission input shaft is concentric with the crankshaft and flywheel, it has nothing to do with the clutch...
Old Jul 30, 2015 | 10:00 AM
jimbo74's Avatar
Veteran: Air Force
Cranswick, I know the throwout is attached to the fork, it is probably around 3". But is there a traditional pilot bearing? When I called Mitsubishi, the parts guy said there wasn't a pilot bearing. The pilot bearing I am trying to refer to would be around 1" in diameter, and sit in the middle of the flywheel
Old Jul 30, 2015 | 03:00 PM
CrAnSwIcK's Avatar
you may not have one on your particular year/trim...mine has one, but it's called a crankshaft bushing...it goes normally goes on in the center of the flywheel, lots of cars don't have them.
I will find out for you, but I don't recall there being one when I did the clutch on my 03.
checked ASA, no sign of a pilot bearing on the CS6A lancer
Old Jul 30, 2015 | 03:03 PM
jimbo74's Avatar
Veteran: Air Force
ok thanks....
yeah, when I called the dealership parts dept, he put me on hold, came back, and said that the mechanics said there isn't one, and that was after he searched using the last 8 of my VIN as well
Old Jul 30, 2015 | 03:43 PM
CrAnSwIcK's Avatar
you can download a copy of ASA for yourself...
Old Aug 1, 2015 | 12:52 PM
jimbo74's Avatar
Veteran: Air Force
Asa?
Old Aug 3, 2015 | 11:59 PM
CrAnSwIcK's Avatar
aftersales support application...parts breakdown database for Mitsubishi motors north America...http://mitsubishilinks.com/fsm/mmc-asa_usa.exe
Old Aug 17, 2015 | 04:27 AM
mcgarvey's Avatar
Front wheel drive cars don't have pilot bearings. They exist to support the much longer input shaft on a longitudinal RWD application.
Randal
16
Jul 8, 2014 04:30 PM
etown09
Aug 24, 2012 06:32 PM
travail
Jun 29, 2010 02:21 PM
Gracer26
Mar 19, 2010 09:37 AM
AMX
Apr 21, 2007 04:02 PM
