Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
won't shift into 5th or reverse
Old Aug 11, 2016 | 11:17 PM
bossdavis88's Avatar
So I had to replace the input shaft bearing so I went ahead an went through the rest of the transmission to make sure everything looked ok the sencros are all good everything was in goo shape so I put the transmission back into the car an when I went to bleed the clutch noticed it wasn't shift into the gears so I took the control box out an messed with it everything was kinda stuff so I put gear oil on it an messed with the reverse lockout spring cause it wasn't loading like it should I got that fixed so put it back in now for some reason it won't go into 5th or reverse after I've taken the control box out twice more an can't figure out what the issue is anyone have a clue what I'm missing......?
Old Aug 12, 2016 | 11:13 AM
CrAnSwIcK's Avatar
Shift fork
Old Aug 12, 2016 | 09:08 PM
jimbo74's Avatar
Veteran: Air Force
when my car wouldn't go into 5th or reverse, It had severe issues.... all my shift forks were galled from lack of oil
I ended up getting a rebuilt unit -- not getting mine rebuilt
Old Aug 13, 2016 | 01:04 AM
roni4g63's Avatar
check your linkages on the transmission, the actual cables, any binding will cause this, specially if you say you can engage it by hand.
Old Aug 13, 2016 | 05:55 PM
CrAnSwIcK's Avatar
if shifting between 1 and 2, as well as 3 and 4, and if the shifter itself physically moves to the 5th and reverse positions then the linkage is not the issue.
Old Mar 9, 2025 | 10:05 PM
jackolancer's Avatar
so I’m in the same boat here when reaching down in the engine bay I can physically shift through gears but when I put the retaining bolt in the control housing it’s stuck is it installed wrong or is there more issues I missed when rebuilding!
bnr34rb26dett
Dec 10, 2012 09:33 AM
agy2k2
Dec 20, 2010 08:50 AM
Tractionlimit
14
May 27, 2009 07:26 PM
j14mp
15
May 15, 2008 04:01 PM
