Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Free lancer with clutch issues.
Old Feb 18, 2020 | 12:04 PM
Edwin Colon's Avatar
Short story. I was gifted an 08 gts with a faulty clutch.
before anyone gets upset and tells me to look in the forums I already looked. My issue is alittle wierd.
engine in healthy, tranny has a new clutch installed. It worked fine after install.
Now the clutch is pressurized and pumps but it won't go into gear On or off..
could it be internal or a clutch master cylinder issue. Worked fine before issue commenced.
thanks in advance for your time and patience.
Old Feb 18, 2020 | 03:01 PM
Pal215's Avatar
Have someone look at the clutch fork and slave cylinder while you press the clutch pedal. You should see movement. If not, try bleeding the clutch line and checking for leaks.
Old Feb 18, 2020 | 07:25 PM
thanks, I'll give it a try tomorrow and check those components.
Old Feb 26, 2020 | 11:35 AM
After I flushed 2 bottles of fluid nothing happened no clutch engagement. Would that indicate a bad clutch or a bad master cylinder?
Mattkinn2004
Mar 21, 2011 03:49 PM
THUB
Mar 12, 2008 10:12 PM
boostedwrx
May 30, 2003 08:29 AM
