Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
RRM's new clutch options
Old Aug 21, 2004 | 08:31 PM
pgmike's Avatar
I see that rrm just put up some new options for replacing the lancer clutch. Rob or boe could you shed some light on this? What is inlcuded in both kits? How much power can each handle? etc
Old Aug 21, 2004 | 09:23 PM
gregivq's Avatar
I want to know too!
Give us some info ......... and do you still have the other one available .....
curiosity.
Old Aug 22, 2004 | 12:27 PM
pgmike's Avatar
bump
Old Aug 22, 2004 | 04:23 PM
res0pfbp's Avatar
yea i want to know too. is for the turbo stages of the lancer
Old Aug 23, 2004 | 11:58 AM
gregivq's Avatar
RRM where u at?
Old Aug 23, 2004 | 12:25 PM
Boeturbolancer's Avatar
Stage 1 is basically for those going the NA route and not exceeding 200 crank hp/tq. It has the same feel as the stock... slightly stiffer but not much with the same ease of engagement. The stock feeling though gives up at high HP applications. It will wear better than a stock set, last longer basically, and keep things from slipping on the NA setup. If your staying NA go with this setup.
Stage 2 is for those planning to turbo or staying NA that want the best grip, no slip, fast acting clutch they can get. The Stage 2 is an ACT custom clutch that we had them design for the turbo'd lancer. While you'll have to develope a stronger leg to push this baby in you'll like the feel once you dump it and it sticks. I had this same clutch in my car and even when i was pushing over 260whp it never slipped once on the dump. It hooked evertime, all the time!!
Old Aug 23, 2004 | 12:28 PM
Danno's Avatar
In the picture of it, it looked like it came with the throw-out brearing. Is that correct? Is is better then the undersized crappy stock one?
Old Aug 24, 2004 | 11:18 AM
duc749's Avatar
[QUOTE=Boeturbolancer]. While you'll have to develope a stronger leg to push.....QUOTE]
That is an Understatement
Old Aug 24, 2004 | 03:16 PM
pgmike's Avatar
boe, so at what point did you need to upgrade your clutch?
Old Aug 25, 2004 | 07:32 AM
I did it at the same time i did turbo... i didn't want to wait and i was doing the LSD anyway. Thus i put it all in at once.
Old Aug 25, 2004 | 12:36 PM
pgmike's Avatar
so do we really know when it is realy needed then?
Teamlift
Lancer Engine Tech
Jun 17, 2016 01:53 PM
ishotphish
31
Mar 2, 2016 04:05 PM
JRR
For Sale - Cars For Sale
12
Jun 2, 2011 07:15 PM
aem_power 17
26
Feb 12, 2007 07:34 PM
Xshieldsx
18
Dec 12, 2005 11:25 AM
