Road Race exhaust section rattling
Old Nov 18, 2002 | 04:01 PM
crusin_lancer's Avatar
Exhaust piping
Not a big problem, but a concern I have. I installed the RRM exhaust and it is centered and looks real nice, but the piping seams to bump the kit for the sway bar and sometimes taps it when hitting bumps. Not sure if this is normal or what measures I can take to stop the tapping. Just sounds wierd. If you need more detail I can take a digital picture if needed.
Old Nov 18, 2002 | 04:26 PM
LBLancerDude's Avatar
mine does it too... i just kinda gotten used to it... but if rock designed it to not do that then there may be a problem... i wouldn't mind getting that fixed though
Old Nov 19, 2002 | 07:33 AM
ok at least I'm not the only one. Just seemed weird because an inch or so over and it would be fine.
Old Nov 20, 2002 | 12:52 PM
SpeshalK's Avatar
Rrm Exhaust
I just got my exhaust put on today, and i was just wondering if it is normal for it to shake when the car is being started...
Old Nov 20, 2002 | 12:57 PM
LaNceRiTiZ's Avatar
...mine shakes a bit ..
from the vibration....
there has been a thread before..bout rrm exhaust
not put on correctly...
the car does vibrate when you start it..
Old Nov 20, 2002 | 01:16 PM
raul's Avatar
Stock one shake too it is just now with tip you can see it shake. Maybe you need to put the bolt on the lower of the back tab by the tip.
Old Nov 20, 2002 | 02:10 PM
SWIFT1's Avatar
my exhaust shakes when i start the car . . . its not a problem though . . .
Old Nov 20, 2002 | 03:09 PM
wags528's Avatar
mine used to shake too - - - because the rrm exhaust is thicker in diameter it may tend to rattle against the rear sway bar mount every now and then . . . . . . what i did to solve this is this:
on the exhaust mount at the front of the RRM exhaust i put some washers on it in between the rubber mount and the exhaust mount . . . this held the pipe a little bit further away from the sway bar mount and thus stopped the rattling . . . . it still hits the mount every once in a while if i hit something hard or go too fast over a speed bump, but it happens alot less than it did before . . .
the end of the pipe is still centered in the cut out too
Old Nov 20, 2002 | 03:14 PM
wags528's Avatar
EDIT - -ignore this post - i had posted it somewhere else and then it was moved here - - the link was to this thread from another thread - - -if u understand that . . haha
look here
check that - -
mine used to do that too, but i sort of fixed it
i just posted in that other thread what i did to fix it . . PM me if you want more details . .
Old Nov 21, 2002 | 11:43 AM
link didn't work... I might try that washer idea... any pics?
Old Nov 21, 2002 | 09:29 PM
wags528's Avatar
no, but if u give me til this weekend and providing it stops raining outside ill take some pics of it with my digi cam and help you out ..
Old Nov 21, 2002 | 09:35 PM
what was the link about then?
Old Nov 22, 2002 | 05:23 AM
wags528's Avatar
there was two posts on the forums about rrm exhaust rattling - - i had posted in this one and then posted in the other one and had the link to this thread . . . one of the mods must have combined the two threads and thats why the link didnt work because it was a link to this thread
Old Nov 22, 2002 | 05:42 AM
agsmooth84's Avatar
my exhaust shakes when i start my car, just something to get used to
Old Nov 24, 2002 | 03:23 PM
hardcoretuner's Avatar
my stock shakes a lot! i just bought my new exhaust (buscher racing) and i am worried that if it shakes as much as this one the tip will kick the crap outa the bumber the new tip is 4in and the stock tip is 3 any ideas to help reduce the shaking
