knocking lifter??
Old Nov 26, 2002 | 04:47 PM
StreetLancer's Avatar
I was curious about the 2K startup thing too... Mine starts up at 2K in cold weather, and then drops all the way to 1K (normal) given time to warm up, or if driven for a bit. It's almost like a built in warm-up timer....
Old Nov 26, 2002 | 04:54 PM
cwest's Avatar
k', gotta go.
Old Nov 26, 2002 | 04:56 PM
cwest's Avatar
any info that anybody has on it would be appreciated. thanks.
Old Nov 26, 2002 | 06:37 PM
LBLancerDude's Avatar
mine starts at 2k in hot weather... so i dunno man
Old Dec 1, 2002 | 08:28 PM
NivenHuH's Avatar
*shrug* mine is at 2k in cold weather and starts at 900 or so in normal weather.. I thought it was something they had programmed into the ecu to warm the block up prior to driving.. *shrug*
Old Dec 1, 2002 | 08:35 PM
bahamut's Avatar
Originally posted by cwest
'aight. How about the squeak from the steering colum area? heard anything abot that?
Steering column or P/S assembly?
If the latter, just tighten the belt. apply pressure from your thumb on the belt. If it feels like your thumb is about to break off, it's tight enough.
As for high idle in cold weather, normal. In hot weather, do you have an intake or messed with the throttle cable?
2003lancer's Avatar
mitsubishi does not have a adjustable lifter like other cars, they have what they refer to as a hydrolic lash adjuster. i have had 3 mitsu's now and they usally run about 15 each at mitsu service department. real easy to swap out. i highly recomend changing all of them at the same time. you can tell wich one is bad by simply looking at bottom of it and if it looks like its been hammered on its the bad one
DELancer08
Oct 2, 2009 10:11 AM
RsxTypeS-2-Evo8
39
Mar 22, 2008 01:27 PM
RUN FOREST RUN
Feb 12, 2008 07:46 PM
Nevaeh
Lancer Engine Tech
23
Jul 2, 2005 08:38 AM
