cant get it back on!! please help
Old Jan 30, 2003 | 09:17 PM
proachbass91's Avatar
i took off my door panel today to try to put in new speakers.... well actually to get the specs on the custom mount i have to make..... but i went to put the pannel back on and i got everything on except the plastic piece that goes by the door handle...... can any one help me?..... please.... door works fine w/ o it jus want it back on
Old Jan 30, 2003 | 09:30 PM
Sonantoni's Avatar
Lightbulb
If you look at the back of this plastic piece you will see a clip and this clip will point toward the front of the car. When installing you have to open the door handle and then insert the side with the clip first(while holding the door handle open) and then push the other side(which should have 2 holes, one on the top and one on the bottom)these will click into place. If you still need help, I will get pictures. I know that sometimes using pictures while explaining helps out.
kyleh10
Apr 28, 2015 09:31 PM
princess33
Apr 10, 2013 12:40 PM
BoostedAWD91
Mar 28, 2013 11:21 AM
da2003pizimp
May 6, 2005 06:17 PM
nightrider
Lancer Troubleshooting
Mar 2, 2003 10:55 PM
