Help! B&M adjustable short shifter install problem
Old Apr 8, 2005 | 10:52 PM
grubiaco's Avatar
I wanted to do a short install but it didn't work. I wanted to know if the blue aluminum pivot is suppose to slide with ease onto the shifter? The reason why I am asking is because mine doesn't go down the shifter.
The stopping point is somewhat around the bend. Can some please help me out.
because I am thinking I am just going to grind the pivot out and make the whole a little wider.
Old Apr 8, 2005 | 11:05 PM
03RallyLancer's Avatar
what do the instructions say? b&m i hear instructions tend to be quite good
Old Apr 8, 2005 | 11:10 PM
grubiaco's Avatar
The instructions are pretty good. Here they are: https://www.evolutionm.net/features/...vomfeatures/42
Has anyone else experienced this?
Old Apr 8, 2005 | 11:14 PM
are you saying the lil blue ball isnt sitting sitting right in the shifter retainer (the white plastic peice) or are you asking something else
Old Apr 9, 2005 | 12:30 AM
grubiaco's Avatar
The blue ball (pivot) isn't sliding down the shifter.
Old Apr 9, 2005 | 10:16 AM
grubiaco's Avatar
Bump. I need someone to confirm my problems.
Old Apr 9, 2005 | 10:48 AM
rcefstsfecr's Avatar
Pictures of what you are talking about will help clarify.
Old Apr 9, 2005 | 10:53 AM
wingnut17's Avatar
The ball is supposed to be here, Where are you having trouble? Are you saying you can't get the little ball past the bend?
Old Apr 10, 2005 | 09:48 PM
grubiaco's Avatar
yea the pivot (Blue ball) isn't sliding pass the bend. Anyone have the problem and if so what was your solution.
Old Apr 10, 2005 | 11:47 PM
grubiaco's Avatar
bump for suggestions
Old Apr 10, 2005 | 11:52 PM
jeffm1999's Avatar
heat up the blue ball in the oven and it will expand.... 350 degrees for about 10 minutes and you are on your way.l
Old Apr 11, 2005 | 02:08 AM
grubiaco's Avatar
I'll try that. Thanks for the advice. Any other solutions, because I won't work on it until next weekend.
TWM Performance
Feb 28, 2017 07:36 AM
Kracka
83
Jan 20, 2017 12:54 PM
Evolved X
16
Dec 30, 2015 12:21 PM
Ace King
Mar 13, 2012 02:14 PM
03RallyLancer
Dec 21, 2004 10:33 AM
