Short shifter install
Old Dec 20, 2004 | 12:07 PM
03RallyLancer's Avatar
Hey guys i just got the kartboy shortshifter... and i havent been able to find an install on the lancer just the evo... my question is do i need to get a new pivot cup like the evo or is ours not attached? thanks for the help guys.
Old Dec 20, 2004 | 12:30 PM
digdat's Avatar
http://www.angelfire.com/linux/sicktght/short.html
you should be able to reuse the pivot cup.. just be careful when removing. its very easy to install this.
Old Dec 20, 2004 | 12:44 PM
Shingen's Avatar
make sure to put greese on that sucker too. The evo instuctions should be the same as the lancer.
Fox
Old Dec 20, 2004 | 07:09 PM
so then i dont need to buy anything extra except some all purpose grease?
Old Dec 20, 2004 | 09:47 PM
r3z0nate's Avatar
I managed to re-use one of the two pivot cups, learning from my mistake after i broke the first in half. Cost me $5 for a new one and an extra 30mins to put it in. Taking it off with the edge of a table worked for me the second time but does it fly away.
Old Dec 20, 2004 | 09:50 PM
MalibuJack's Avatar
Your best bet is to get the retainer and cups anyway, save your old shifter with the original parts on it.. (trust me, its worthwhile to throw it in a box and save it)
The install is the same for the Lancer and Evo..
Old Dec 20, 2004 | 10:32 PM
ambystom01's Avatar
Its not a hard install, took me like an hour. I'd recommend replacing the shifter base bushings at the same time. To get the pivot cups off I just put a towel around them and used a wrench to pry em off. Took like 10-15 min.
Old Dec 20, 2004 | 11:23 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Yeah, I wrapped a hand towel around them and used a pair of channel lock pliers to get the cups off. I would have bought new ones if the instructions had mentioned it at the beginning instead of half way through when I'm stuck in a garage with a car with no shifter
btw, I believe you're supposed to use lithium grease. Don't just get WD40 or something like that, it might eat the plastic.
Old Dec 21, 2004 | 10:33 AM
Blacksheepdj's Avatar
And grease the heck out of it. When I did it, I kinda thought "gee, that doesn't look like enough grease." I was right - mine already needs more.
roger0416
Oct 11, 2016 08:43 PM
jakebehan95
Evo X How Tos / Installations
Aug 16, 2015 07:52 PM
J Yim
Mid-Atlantic Region
Apr 29, 2009 03:43 AM
EE
Nov 12, 2007 02:53 PM
ammitsuevo
Mid-Atlantic Region
Jan 21, 2004 02:55 PM
