Which wire is the correct one for a air/fuel gauge?
Old Mar 22, 2003 | 06:11 PM
BuMpS's Avatar
Well guys I just tried that Blue/Red wire and no luck now I'm thinking that still may be the correct wire it just may be where I got my power and ground I don't exactlly see that mattering but in the world of wiring who knows !! Blah!! oOh well thats enough playing for now I gotta get ready to go out... I'll play with it some more tomorrow...
Old Mar 22, 2003 | 06:23 PM
cincyracer2002's Avatar
where can i get the diagram, also what do i do to install my S-AFC?
Old Mar 22, 2003 | 08:40 PM
BuMpS's Avatar
LOL you wait till it's 4 in the morning and your really bored and you go outside and you take your glove box out an put it in the back seat then disconnect your battery... then you proceed to lay upside down in the passenger seat of your car and begin splicing the correct wires for the specific setup you are using...if u already have your AFC look in the manual for the wiring diagram you can use... I believe it's diagram M3-A under mitsubishi (of course).. After installing the AFC, you should invest in the air fuel gauge you won't be able to read air flow with the Karman ECU setup. so the A/F Gauge is your best friend I'll explain more later, although I'm sure someone else will before me..Umm ugh run a search to man, I just installed mine n we covered the install on here.. I had the idea of it down but, Rhyzin and a few other memebers on here helped me out a lot, with any of the problems that I ran into.. Good luck man
Old Mar 22, 2003 | 11:16 PM
i bought it used without a manual, anyone want to send me theirs?
Old Mar 22, 2003 | 11:25 PM
rhyzin's Avatar
follow this for the a/f gauge my peoples! it should be one of the white wires... the middle of the three, i think. and on a side note, this diagram is from the wire side of the harness. not the socket side.
Old Mar 23, 2003 | 06:59 PM
BuMpS's Avatar
Hey guys whats up.. Ya that diagram and Rhyz is right it's a white wire the 6th 1 in.. It's kinda funny that my diagram from mitsu was wrong... Anyways now I didn't get my power or ground source from the locations in the above picture but I tapped into that white wire and walaaaa it works... hope it works for the rest of you.
Old Mar 31, 2003 | 12:31 PM
wags528's Avatar
i got mine hooked up this weekend, works good thanks to Boeturbolancer for all the help
Old Mar 31, 2003 | 01:23 PM
Boeturbolancer's Avatar
No Prob glad it worked out for you
Heebs 09gts
May 31, 2016 08:24 AM
Giuna99
Mar 5, 2016 02:03 PM
Veronica
Mitsubishi TC-SST Discussion
Aug 9, 2015 02:09 PM
twnty100drummer
Jun 13, 2010 02:52 PM
trinydex
Mar 29, 2007 05:38 PM
