my rpm fluctuates
Old Feb 6, 2003 | 08:20 PM
jabrien00's Avatar
I guess just keep cleaning and oiling it every 1,000 miles
pjal84's Avatar
Like the man said keep it clean and don't replace it with a garbage Ractive element for the love of God. If you really want to replace it, slap on the A'pexi Power Filter or something like the Blitz SUS filter.
Old Feb 8, 2003 | 01:08 PM
jason33hs's Avatar
The Lancer actually has a small valve screw mounted on the throttle body. The check engine light will come on once the OBDII catches the fault. It is a warranty repair for most of us since the Lancer is new in 2002. If you repair it yourself, make sure to ge the o-ring for the mounting since the other will most likely tear when you remove the faulty one. Good luck.
Old Feb 8, 2003 | 01:54 PM
Dem1K's Avatar
not to sound stupid but how exactly to u d/c the battery? do u take off the + or - ? or what do i do? thx
Old Feb 8, 2003 | 01:57 PM
pinoyesv6's Avatar
2 things. the battery, disconnect the black side first. secondly, uhm did u check ur throttle body? is it clean? try cleaning it
Old Feb 8, 2003 | 02:00 PM
Dem1K's Avatar
how do u clean your TB?
Old Feb 8, 2003 | 07:37 PM
pjal84's Avatar
I'd say try using carb choke cleaner (that stuff will dissolve most if not everything) buuuut, not to sure.
clanzkiller
25
Mar 15, 2017 09:55 PM
Jakdup36
10
Dec 14, 2016 03:44 PM
Lvchief81
Feb 10, 2016 09:47 PM
Randal
Nov 27, 2012 06:22 AM
purevo96706
Dec 18, 2008 07:55 AM
