Interior question
Old Apr 29, 2005 | 10:18 AM
TeamAccolade's Avatar
Interior question
How do i get the Grey Plastic (OZ) pieces off from behind the seatbelts?
i can get it to pop off a little but how do i remove the belt to get the piece off for painting?
Old Apr 29, 2005 | 10:21 AM
twardnw's Avatar
I would assume you can unbolt everything
Old Apr 29, 2005 | 10:29 AM
...? i don't think that would work. seeing there are no visible bolts. the piece is held on by the little seat belt thingy... (the adjustable plastic piece)
Old Apr 29, 2005 | 10:46 AM
Guru_Del's Avatar
ok the seatbelt thing splits in half. there is a bolt behind it i believe 18mm but could be wrong. once you take that out then the seatbelt comes off.
Next you will need to pull the black peice out alittle (the bottom part of the b pillar) it just takes some mussel to split it and work it.
next take the weather stripping off the door jam around the plastic peice that you want to remove and it should slip up alittle and pop out.
repeat in reverse order to install.
just did it the other day to put em back in so if you have any q's let me know
Old Apr 29, 2005 | 10:52 AM
i have the black pieces off, but i can't seem to get the grey piece, i have got it past the weather stipping already, but i can't find the bolt holding the seat belt up there. ( i know there are 2 by the black piece, one behind and one coved b/c the carpet....)
Old Apr 29, 2005 | 01:26 PM
got it off, just realized what you ment.... wow that was a lot easier thanx for your help!
maggieau1
Nov 22, 2015 09:16 PM
WildOne
Jul 20, 2008 04:19 PM
Evo05lution
Mar 7, 2007 05:58 PM
hypo74
Lancer Engine Tech
17
Jan 21, 2007 01:54 AM
Tsurara
Jan 7, 2007 08:25 AM
