Mass Air Flow Sensor Problem
Old Jun 9, 2005 | 10:04 PM
Punz0247's Avatar
Unhappy Mass Air Flow Sensor Problem
I've put a new cold air intake and now my check engine light is on.... put the scanner to it and its the MAF sensor.....its not damaged in anyway...its on properly....i still have to check it for leaks just in case but would anyone have any suggestions?
Old Jun 9, 2005 | 10:10 PM
evo1919's Avatar
did you try to disconnect the battary??
also..you will need a tune to get the power from intake..
Old Jun 9, 2005 | 10:15 PM
Punz0247's Avatar
Yea i reset the computer....and when u say tune u mean a tune up? if thats the case i might still have at least 1000miles left till thats done but if it would help then screw it i'll do it.
Old Jun 9, 2005 | 10:17 PM
maxum17ft's Avatar
no he has an evo 8, u should never need a tune w/ a regular lancer until major mods. u must have f'ed up the maf honeycombs. or u didnt reset battery, or u didnt plug maf back in all the way.
Old Jun 9, 2005 | 10:18 PM
maxum17ft's Avatar
tune up wont do anything, except maybe run smoother
Old Jun 9, 2005 | 10:19 PM
ambystom01's Avatar
Yeah recheck the MAS hookups and the condition of the honeycomb.
Old Jun 9, 2005 | 10:25 PM
Punz0247's Avatar
MAS is fine....cant screw it up by unscrewing it and putting it down.....im just stumped.... we tried to clear it wit the scanner but as soon as it goes off...a second later it comes back on... im gonna take it apart this weekend and redo it... but i have a feeling its not gonna fix the problem for some reason..
machron1's Avatar
CAI are known to let turbulant air pass over the MAF sensor and cause problems.
Old Jun 9, 2005 | 10:29 PM
evo1919's Avatar
oh sorry...my bad.
Old Jun 9, 2005 | 10:32 PM
Z_Lancer_Man's Avatar
1. Recheck all MAF wire connections
2. Unhook negative battery cable and let sit for 15 minutes.
3. Replug battery and let car idle for 10-15 minutes.
That should fix it. Also as mentioned above, check the honey comb on the MAF. When I installed my CAI, I accidentally drop the screwdriver on the honeycomb. I fixed it though and haven't ever had a problem.
Old Jun 9, 2005 | 11:44 PM
SIMSSEGA's Avatar
are you sure its not backwards?
Old Jun 10, 2005 | 08:27 AM
HobieKopek's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=141865
His first thread.
You don't really need to tune just for an intake. Resetting the ECU should be more than is even necessary. You said your friend had a scanning tool. Use it! Get the code, find the problem!
Old Jun 10, 2005 | 08:43 AM
wiretap's Avatar
If all else fails, and the MAS is broke beyond fixing, check a junk yard, or advertise in the wanted section.
Old Jun 10, 2005 | 05:10 PM
HobieKopek's Avatar
Or give me a million dollars for mine.
Old Jun 10, 2005 | 05:18 PM
Alchemist's Avatar
Well, it's teardown time:
Take everything apart.
Inspect the MAS for damage. If the veins are bent, carefully use an allen wrench to push them out from the good side. I don't remember what size, but this will work.
Put the hose back on the TB
Put the MAS back on the hose. The flat access panel should be on top. The harness should be on the left side as you're facing the engine.
Reinstall the CAI (stock airbox would be better to eliminate the possibility that the CAI is the issue, but it's probably too late for the airbox )
Good luck
