Aem Ram Air
Old Jun 26, 2005 | 10:13 PM
lancer5spd's Avatar
Aem Ram Air
well it all started when i put that dam thing on it was fine then the mafs went bad i check it out and every thing is peachy cel gos off and then back on again everything is set up right and i have a bypass valve on as well . but to get to the point the AEM intake is putt'n on the light is injen any good ??? and i did replace the mafs and guess what ......... the light is on again and well does anyone know what the prob might be >
Old Jun 26, 2005 | 10:18 PM
CenCoastOZ's Avatar
you make sure that you didn't put the MAS backwards? did you plug the MAS back in as well?
Old Jun 26, 2005 | 10:22 PM
lancer5spd's Avatar
trust me its in the right way
Old Jun 26, 2005 | 10:24 PM
HobieKopek's Avatar
How do you know the MAF is bad? Posting a pic of your install would be helpful for troubleshooting too.
Old Jun 26, 2005 | 10:27 PM
lancer5spd's Avatar
i did a scan on it and got a new one you know mafs do go bad even on new cars im just the unlucky one who has been **** on
Old Jun 26, 2005 | 10:31 PM
HobieKopek's Avatar
Yeah...I know they go bad. And I'm sure you don't want to hear this, but punctuation really helps get your point across.
I dunno though...it seems really unlikely to me that 2 MAFs just suddenly failed. The intakes themselves do little to modify air flow, and the fact that none of the FI Lancers, most of which still use their stock MAF sensors with significantly increased flow, have had failures. It's far more likely that either they both got damaged or the ECU code is misleading.
Old Jun 26, 2005 | 10:32 PM
lancer5spd's Avatar
ecu that a word i dont wanna think about i will look into it thanks
Old Jun 26, 2005 | 10:45 PM
HobieKopek's Avatar
Well...the ECU is what gives you CEL's so it's something you need to consider. It will only put out what it reads in, but the codes it throws don't necessarily indicate failure so much as irregularity. Did you reset the ECU when you installed the intake? It's possible that the ECU simply started throwing a CEL because of the change in air volume or velocity. I wouldn't say that's 100% true, and you may very well have gotten two failed MAF's, but if that's the case I think you could get a write-in vote for worst luck modifying a Lancer. Nobody's taking the gold from me in that category though.
Benson830
Nov 8, 2016 09:32 AM
Dross99_si
Mar 4, 2016 08:27 PM
seven10
Sep 29, 2015 02:48 PM
blowngasket
Mar 31, 2012 10:22 PM
snowmastergt
Feb 14, 2012 01:19 PM
