Idle problems..
Old Jan 2, 2006 | 03:56 PM
impetus19's Avatar
Idle problems..
I noticed today after doing a log that my idle afr's are quite lean, around 17:1... The car runs fine and idles fine the afr's were just worrying me.
The strange thing is that as soon as I start driving the ratios return to their normal 14.7 range in closed loop and in open loop they are around 12.5 exactly what i have it tuned for.
Anyone have any ideas? could my first oxygen sensor need replacement. My idle afr's used to be right at the 14.5-14.9 range. I reset the computer but it didnt change anything, could it be a vacuum leak?
Old Jan 2, 2006 | 04:53 PM
gregivq's Avatar
I don't think it could be a vacume leak since your open loop is fine.
Since you have Emanage try adding some fuel to idle.
Old Jan 2, 2006 | 04:58 PM
impetus19's Avatar
i tried to add fuel at idle but, it seemed to just readjust my settings. It is as if my ecu thinks 17:1 afr is stoic.
Old Jan 5, 2006 | 08:34 AM
comatose721's Avatar
my car idles around there as well...always has. it is never an issue though. once you apply some throttle it returns to a burn much closer to stoich (14:1 - 15:3) when you are just cruising around. open throttle it returns to 12:1 - 13:1 (and i pray to god i don't start knocking when that 13 shows up at open throttle). like greg said though. try playing with emanage a little more. there should be a way to over-ride its 'auto' setting that keeps changing what you set it too.
Old Jan 5, 2006 | 09:00 AM
gregivq's Avatar
^Why are you afraid of that 13?
Old Jan 5, 2006 | 10:27 AM
impetus19's Avatar
I just bought a OBD scanner so I am going to check the codes my cars is pulling.. If it is still only the catalytic converter code I am not going to worry about it.
Old Jan 7, 2006 | 03:07 PM
impetus19's Avatar
never mind.. thanks for the help. I found an exhaust leak today which was causing the lean idle readings.
Old Jan 7, 2006 | 08:42 PM
i read that the car starts knocking around 13:1...it could have been inaccurate though.
07EvoIX
11
Jun 6, 2012 03:29 PM
holmes14
Mar 28, 2011 07:24 PM
R0b
Mar 21, 2011 06:49 PM
SeanV
Oct 7, 2009 09:35 AM
mega-z
13
Mar 13, 2009 01:05 PM
