Problem... is anyone outhere?
Old Jan 31, 2006 | 06:35 AM
omarbermejo's Avatar
Hey guys this is my problem. I install the RRM Header into my 02 Lancer OZ. of course the "check engine" light came on but the header was well installed and everything was working fine, so i didn't mind then.
well now that I moved to california the DMV is asking me to do a smog test, but my car won't pass the test because of the "check engile" light. I do not want to re-install the stock header and do the smog test.
Is there a way my car can pass the test with the RRM header? any help? thnx.
Old Jan 31, 2006 | 06:37 AM
Johns Slow ES's Avatar
RRM sells a cel fix for the header
but i know cal is brutial on testing so u might have to swap it out
Old Jan 31, 2006 | 07:44 AM
Walkingchaos's Avatar
hate to tell you this bro but your car wont pass AT ALL untill you get a stock header back i nthere. Hope you kept your original. I just moved back from Cali and before i left i tried to sell my old car which was modded to all hell. I had to spend over 600$ in parts at a junk yard to get it to pass. That header does not have a CARB exempt number on it and therefore will NOT pass. Sorry man.
Old Jan 31, 2006 | 08:45 AM
sthiewes's Avatar
Just flip your cat around so your O2 sensor is in the back. That'll make your CEL go away.
Old Jan 31, 2006 | 09:08 AM
gregivq's Avatar
^This doesn't work every time! Flip the cat and use the cel fix. Or just take out the light bulb from the SES light.
Old Jan 31, 2006 | 09:16 AM
sthiewes's Avatar
^Oh I did not know that. It worked for me and I never had a CEL.
Old Jan 31, 2006 | 09:21 AM
blaze_125's Avatar
DO NOT DO THAT. When you'll go for your test they'll hookup an obdII reader to your Ecu. Even if you take the bulb out the code will still be stored in the Ecu. Get the code erased a few minutes before you drive in there and you should be fine(ObdII wise). I don't know about emission though.
Old Jan 31, 2006 | 09:26 AM
its not just the CEL guys, in Cali they do a full visual inspection of EVERY part of the emissions system. As soon as they see an aftermarket header (and they wont miss it) youll fail. Dont waste the 35$, put your stock header back on before you go.
Old Jan 31, 2006 | 10:47 PM
Thanks guys.... I really appreciate it.
Old Jan 31, 2006 | 10:54 PM
Handmemyarms's Avatar
just install the old one and skip all the BS, your all making too much of this when he has the option of just putting the old header back on, its not that hard, ive done it.
Old Feb 1, 2006 | 07:15 PM
jchangsta2six's Avatar
just take it in and slip him a washington and and and then walk away
Old Feb 1, 2006 | 07:43 PM
i tried that when i was there, they are cracking down on it and its harder and harder to "buy" a passing grade >=)
Old Feb 2, 2006 | 07:29 AM
Danno's Avatar
Everyone has there price, it just depends on what its worth to you to spend.
22raptor
23
Sep 13, 2011 11:18 AM
rastaj0ker
Lancer Troubleshooting
Oct 26, 2009 08:13 PM
Gonzo314
Jul 3, 2006 05:24 PM
Hotshot940
Lancer Aftermarket Forced Induction Tech
Mar 2, 2005 11:43 AM
trance
Lancer Engine Tech
Aug 11, 2003 08:25 PM
