Clutch Problem?
Old Feb 23, 2006 | 11:29 AM
Lancer8806's Avatar
Clutch Problem?
I drive a 2002 Lancer OZ with about 48k on it. I bought this car about 2 months ago. My problem is that everytime I down shift to accelerate or just lay on the throttle my car jumps in RPM's, say from 3,500 - 5,000 and goes no where. (as if i was depressing the clutch) After it jumps in RPM's it slowly decreases in RPM's and accelerates. I have already taken it back to the dealership, and the mechanic there claims there is no problem. I think that the clutch either needs replaced or adjusted. Any other ideas?
I did search this, didn't find anything too helpful.
Thanks for your time
Old Feb 23, 2006 | 11:43 AM
gregivq's Avatar
It's that new recall problem. The problem isn't mechanical, it's in your ECU, whatever reflash your dealer causes the problem.
https://www.evolutionm.net/forums/sh...ghlight=Recall
Old Feb 23, 2006 | 12:13 PM
Lancer8806's Avatar
I think that's something else. my car does idle high, but it soon lowers. The problem in my situation is that it's un-responsive, if i accelerate hard it does nothing.
Old Feb 23, 2006 | 12:22 PM
gregivq's Avatar
Why do you think it's a clutch problem? I think if it would be because of the clutch it would happen all the time.
Old Feb 23, 2006 | 02:58 PM
Lancer8806's Avatar
I have always thought that it was a clutch problem.
For one, it has that distinct rubber burning smell, like when you would slam on the brakes.
Two it has progressivly gotten worse.
And just today I could not get it to go into reverse.
Old Feb 23, 2006 | 03:08 PM
Go2fast's Avatar
must likely its ur clutch. Lancer clutches arent that great!! Sounds just like the clutch slipping. Replace the clutch. You cant adjust our clutch b/c its hydralic.
