Startup problems...
Old May 25, 2006 | 01:20 PM
sykou's Avatar
Startup problems...
Okay first off my list of mods...
- AEM Cold Air Intake
- RRM Headers
- RRM Piggyback V2
- DIY Grounding Kit
- 2.25" custom catback
So the problem is when i start. It starts cleanly like usual but dies right after i start it up. Sort of like when your fuel pump isn't connected. The engine doesn't choke or anything. Hope you guys can help! Thanks!
Old May 25, 2006 | 02:26 PM
Wallesasuaz's Avatar
Could be the piggy or the Intake.
Is this the first time it happens to you? What did you do before this happened? When did it start happening?
We need more details.
Old May 25, 2006 | 03:17 PM
comatose721's Avatar
had you been playing with the car lately?
check your MAF/MAS plug and make sure it is on snug, make sure all the wires to the piggy have good connections, and try listening for the fuel pump when you turn the car over to see if it clicks on.
Old May 25, 2006 | 10:24 PM
sykou's Avatar
Started happening right after i put the ground wires in....
Happens on rare occasions. Randomly it seems...
The weird thing is that i try to start it up and it dies, then when i start it up again, it starts perfectly normally...This is with no movement of the car whatsoever.
sykou's Avatar
WHat do you mean by playing? You mean driving it really roughly? or messing with the maps?
Old May 26, 2006 | 07:25 AM
all of the above. driving hard, messing with fuel maps, adding new mods, doing maintainence, etc. you said you just installed a ground kit? do you think that the problem could be related?
Old May 26, 2006 | 07:48 AM
Did you install the Grounding Kit properly?
Maybe there's a slight surge or something making your car lower in idle and making it stall. That's just a theory. This is really strange... practically a guessing game!
Old May 26, 2006 | 10:39 PM
sykou's Avatar
okay another thing i noticed is that it only dies after the engine is near or at normal operating temp. Doesn't happen if the engine is cold. kinda weird ya. Ill try removing the ground kit tomorrow to see it the problem goes away.
Old May 26, 2006 | 10:40 PM
sykou's Avatar
i always drive rather hard so i dont think its that. do you think its the fuel pump dying out? or maybe a delay in the piggy, sort of like the delay that causes the studder?
Old May 27, 2006 | 09:23 AM
how'd removing the ground kit work? make sure the PB ECU has good connections. that could be the problem.
Old May 27, 2006 | 09:47 AM
DemisedGabe's Avatar
its probly the ground kit, Im not trying to insult u or anything but everything u tack it too has to be metal, that can be ur problem
Old May 29, 2006 | 04:23 PM
sykou's Avatar
I removed the grounding kit from the alternator and i haven't had any problems since. Might be due to the wiring setup i had. Changed it into a simpler one and no problems so far. *knock on wood*
Old May 29, 2006 | 08:23 PM
good
js0102
Lancer Troubleshooting
15
Sep 22, 2009 06:34 PM
mitzugsx
Lancer Engine Tech
Jun 9, 2009 12:18 PM
mitralliart
Lancer Engine Management / Tuning Forums
14
Mar 5, 2009 12:03 PM
04WhiteRalliart
Dec 24, 2006 01:49 AM
Gr33dyMitsU
12
Nov 23, 2006 06:17 AM
