Cat Problems?
Old Jun 29, 2006 | 07:09 AM
BlueIrishs2k's Avatar
Cat Problems?
A couple weeks ago my car through an SES. I got my notice about the pre-warming on the cat a couple months ago but kept putting off going in. When the SES is came on I decided it was time to take it in. I have an aftermarket header (RPW) and exhaust but never had issues with the SES before. I took it in, they worked their magic, and the SES went away...until a couple days later. It's back now and I'm wondering WTF. Is it possible that my cat is going or has gone bad? I've got about 62k on the car but I do drive pretty aggressively. Plus, would you think that the issue with the 'service bulletin' would cause premature death on the cat?
Old Jun 29, 2006 | 07:15 AM
Bigjoeski05's Avatar
If you threw a CEL it's gotta be from the header you need to pick up the CEL Fix from Road Race.
Old Jun 29, 2006 | 08:36 AM
comatose721's Avatar
pull the code. it's probably from the header.
Old Jun 29, 2006 | 10:18 AM
I would think it's the header but I've had it on for over a year with no issues. Why would the header suddenly start forcing the code?
Old Jun 29, 2006 | 10:26 AM
the PCM reflash mitsu was using for the recall makes the heated o2 sensor in the cat operate on a different signal if i remember correctly...essentially it's sending a different signal back to the ECU.
Old Jun 29, 2006 | 10:59 AM
So I get that but the code actually started right before the reflash. That's what makes this whole thing seem so weird. I'm wondering if I should just replace the cat and see if it goes away. Nice Magnaflow high-flow cat would go nicely with my exhaust ;-)
Old Jun 29, 2006 | 11:32 AM
if you have the money to spend on a cat; go for it. OR you could go to autozone and get the code pulled for free and you'll know the real deal.
Old Jun 29, 2006 | 11:41 AM
Makes sense. I'll run by this weekend and see what it says. If it's the same code it through before the reflash then I guess it means bad cat.
Old Jun 29, 2006 | 02:05 PM
Is this the same cat that RRM has?
http://item.express.ebay.com/Vehicle...mdZExpressItem
xXEVOloverXx
Aug 11, 2012 11:24 AM
EvO03
Northwest Region
Jan 7, 2008 07:47 PM
CH4MAN
Dec 19, 2007 12:31 PM
TINMAN
Jan 15, 2007 10:55 AM
majestic lancer
Northeast Region
29
Jan 13, 2004 05:53 PM
