Feels like rotors are warped.
Old May 7, 2003 | 11:16 AM
Volkmann's Avatar
Unhappy Feels like rotors are warped.
I have almost 16,000 miles on my Lancer and when you hit the brakes I feel a slight vibration. I am thinking the rotors are warped. Feels really weird to have the vibration go thru the break pedal.
Old May 7, 2003 | 11:19 AM
Volkmann's Avatar
May have to have rotors turned and add new pads.
Old May 28, 2003 | 07:02 PM
Rbrookstx's Avatar
Got the same problem. I'm going to buy a big brake kit though. IT feels like they are lipped. The rotors that is. But the brake pads are still at over 80%. Dunno.
Old May 28, 2003 | 07:16 PM
Volkmann's Avatar
Yeah I want new slotted rotors and new pads.
Old May 28, 2003 | 07:22 PM
DRC Imports's Avatar
guys just to be informative and try to resolve your issues, im selling powerslot rotors for $80 each plus shipping. they fit the oz/ls lancer and are 10.2" like stock just waaay better. check it out !
https://www.evolutionm.net/forums/sh...ight=powerslot
Old May 28, 2003 | 07:23 PM
and they ship from tx too so little shipping i would imagine !
Old May 29, 2003 | 08:01 AM
Volkmann's Avatar
Ok thanks Ozrallyguy I gotta take a look at the money situation 1st. That is a good price.
Old May 29, 2003 | 08:02 AM
no prob !
Old May 29, 2003 | 08:10 AM
fusoguy's Avatar
Warped Rotors - One Cause
I see that in most instances here, we are dealing with OZ's. One critical maintenance issue, often overlooked, is the proper torquing of the cast wheels. Aluminum, while lighter, is stiffer than a steel wheel and less forgiving. You get some tire jockey running those lug nuts up tight with his airgun set at 150 lb-ft and you can warp the rotors. Check your owners manual for the proper torque spec - usually between 80 and 100 lb-ft. Find a shop that is willing to take the time to use a torque wrench and do it properly. Hope this helps.
Adios,
Fusoguy
Old May 31, 2003 | 03:24 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Just to add to Fusoguy, the Lancer specs (according to America's Tire Co.) on alloy rims is 85 ft/lb
Old Jun 14, 2003 | 11:19 AM
Volkmann's Avatar
Ok had rotors turned at 18,000 miles now they work perfect gotta love warranty.
Old Jul 30, 2003 | 12:01 PM
chriscoker's Avatar
Im having that same vibration when I hit my brakes..I thought it was the Stock Brake pads the first time but I replaced those with new brake pads from $60 shall I add...and it still didnt help...will they Turn the Rotars for Free I have about 27000 miles on my lancer
Old Jul 30, 2003 | 12:05 PM
If they don't, I can get you the powerslot vac-u-slot rotors !! !!
Old Jul 30, 2003 | 01:08 PM
Volkmann's Avatar
My vibration was at high speeds when you apply brake pedal you could feel vibration in the pedal.
Old Jul 30, 2003 | 06:37 PM
KTRLancer02's Avatar
did you check the air in the tires too? You can make your rotors last long if you wash your car when the car/brakes are cold. My pops said washing the car hot makes the rotors warp faster. Sometimes new rotors (regular ones i.e. OEM) cost the same as taking them to a machine shop.
