evo 8 wing install
Old Oct 11, 2006 | 02:37 PM
bene's Avatar
evo 8 wing install
so im installing my evo 8 wing and i was told it bolts right into stock OZ wing holes, i put it on there and its short of the holes on one side by about an inch... did i forget something or is this a faulty wing?
Old Oct 11, 2006 | 02:47 PM
kfos01's Avatar
Actually, if you search you will find that you probably have to drill the holes out a little for the Evo wing to fit
Old Oct 11, 2006 | 02:50 PM
bene's Avatar
oh, k thanks when i try to search it just says memory expired or somethin so it dont work at the moment
Old Oct 11, 2006 | 02:59 PM
kfos01's Avatar
You can't search for things with 3 or less letters. For example: evo wing
That's 3 letters so it won't work. I think at least.
Old Oct 11, 2006 | 03:03 PM
atilla's Avatar
before you attack your trunk with a drill try removing the center piece and putting the side pieces on loosely and sliding the center piece in between both the sides... this is how i got my VII wing to fit perfect.
Old Oct 11, 2006 | 04:53 PM
mitsuozboi's Avatar
it should bolt right up. like atilla said. Attach the sides first then put center in. leave everything kinda loose then once its together tighten it down.
I have installed a evo VII wing and a VIII wing on my 03 oz and both bolted right up perfect.
Old Oct 11, 2006 | 05:12 PM
bene's Avatar
k so after 2 hours of work they fit the stock holes .. just alot of strain on the wing
Old Oct 11, 2006 | 05:29 PM
Walkingchaos's Avatar
wow i put mine on alone without anyone helping thats how closely the holes lined up for ease of install.
Old Oct 11, 2006 | 06:54 PM
bene's Avatar
yeah i bought mine off ebay and hadta refabricate alot of parts... not good quality
Old Oct 11, 2006 | 07:02 PM
Its all about the OEM
Old Oct 12, 2006 | 10:09 AM
SLVROZ_03's Avatar
^^^ Exactly. Mine, on a scale of 1 to 10 was a 1. A few bolts and you're set. Glad to hear you got yours on ! Enjoy!
807JDM
Sep 11, 2016 01:59 PM
ppremier21
Apr 9, 2012 06:59 AM
irulea2
16
Nov 23, 2010 11:50 AM
bbenavitz
May 2, 2006 04:59 PM
dj0521
Mar 6, 2006 09:02 AM
