Weird sound at start up
Old Dec 16, 2006 | 04:53 AM
eyekyu's Avatar
So i just got my belts changed from the mitsubishi dealership drove home fine no problem, had some factory recalls got those fixed. well, i went to start my car @ 2AM, it made this loud *** screech for a good 20-30sec then it smelled like burnt rubber and then it didnt happen again it just stopped the smell went away. Is it something to do with my belts should i take it back?
If this happens again b4 I goto work today in a couple of hours im gonna be worried
any help?
thx
Old Dec 16, 2006 | 04:56 AM
kdwg927's Avatar
Almost definitely the sounds/smells of a belt slipping. I would take it back right away for them to fix it. You're paying the dealer their enormous labor costs, they should at least do it right the first time.
Good luck
Old Dec 16, 2006 | 06:37 AM
comatose721's Avatar
belts. if they changed them when you went for your recall work; the belt stretched (which is normal) and needs to be retensioned. if your belts were not changed when you went to the dealership; it's time for new ones.
Old Dec 16, 2006 | 07:51 AM
dewood*'s Avatar
Okay, here's another question, how do you know what size belts to purchase? Are they specially made for your car or do you have to take the old ones out before you go to autozone to buy?
If i get a pulley from rrm, do i need different size belts than stock, because my car squeals and I want to replace them, so why not add a pulley?
Old Dec 16, 2006 | 02:26 PM
atilla's Avatar
the pulley from RRM is the same size as the stock one--you do not need different size belts. as for an underdrive pulley... yes, then you'd need different belts.
you won't need to bring the belts, just tell them what kind of car it is for and they can look it up in the computer.
Old Dec 16, 2006 | 06:22 PM
eyekyu's Avatar
ok so they fixed it, the belts were hella loose and some part fell off from the alternator
Old Dec 17, 2006 | 10:12 AM
SLVROZ_03's Avatar
^A part just fell off... That's the stealership for yah! Any idea what part it was? like the pulley? LOL
Old Dec 20, 2006 | 11:47 AM
HobieKopek's Avatar
I'm betting it had something to do with the tensioner.
Old Dec 21, 2006 | 10:12 AM
bobaab's Avatar
^ thanks capt. obvious
Old Dec 29, 2006 | 03:20 PM
eyekyu's Avatar
i wish i would of took a pick of it, i think they said the tensioner.
it was a square block, two fatty screws went threw it in two diff directions
but now, when i turn my well if i were to park, it makes this loud are screech. is it still something to do with my belts, does the weather play in this facter? could the belts be too tight or too lose?
Old Dec 29, 2006 | 03:39 PM
Sicktght311's Avatar
God the dealership sucks. When you turn the wheel all the way it puts a strain ont he power steering pump which is connected to the belt. Go back to the dealership and tell them either get the belt right this time, or point you int he direction of the service manager. Gay, i hate the stealership, tightening and replacing a belt isnt that hard of a job haha
Old Dec 30, 2006 | 12:39 AM
eyekyu's Avatar
lol, stealership for sure ill take it monday if they open and tell them. im gettin tired of this bs
tomcoulam
Sep 23, 2012 12:00 AM
simplecomplex
Lancer Troubleshooting
Jan 3, 2012 01:24 PM
WolfsFang
Aug 13, 2011 06:03 AM
PHILLY EVO
May 22, 2008 05:46 PM
Q@EvoPowerMods
Jan 23, 2007 04:02 AM
