RPM bouncing while idleling
Old Dec 20, 2006 | 06:34 AM
Eddiekop98's Avatar
I recently had my timing belt changed and after they did the job I noticed while i'm in park after the car has warmed up or at a stop light the rpm's bounce from about 700 to 1500 to 400. Sometimes I think it may stall. Did the shop not put something back properly while doing the timing belt job or is it something else. I do know I need an O2 sensor is that the problem.
Old Dec 20, 2006 | 06:35 AM
blaze_125's Avatar
any mods on your car?
Old Dec 20, 2006 | 06:37 AM
Eddiekop98's Avatar
no mods
Old Dec 20, 2006 | 06:43 AM
HobieKopek's Avatar
O2 sensor could certainly play a part. The IAC system in the Lancer is very finnicky, so I wouldn't be surprised at all if that were the culprit. Replace the O2 sensor, make sure to reset the ECU, and go through the reset procedure. When you've gotten a few miles on it for the idle tip in/out to teach itself again I'm willing to bet your problem will be fixed. BTW. AT or MT?
heavens turbo
Aug 3, 2016 10:02 AM
Isamu966
Aug 14, 2013 01:23 PM
ThatOneKid
10
Feb 21, 2012 07:53 AM
Dantheman11
Sep 24, 2011 03:23 PM
WickedOne
May 11, 2011 10:53 AM
