Lancer is stalling!
Old May 29, 2003 | 05:06 PM
pickleknock's Avatar
okay, i went out and fully inspected all the connections and whatnot... found the problem. i feel like an idiot. the rubber fitting that connects the intake to the throttle body had come loose just enough, that a gap on the back side opened up. it was just big enough to maybe get a pencil through. i didnt see it at first cause it was on the back side. so i put it back together and reset the ecu to get that damn light off, and now its all good. thanx for the help.
Old Jun 3, 2003 | 02:18 PM
jbj420's Avatar
Originally posted by blaze_125
You might want to check you spark plugs.
Pull your plugs and check the gap. I've had simmilar problem, I adjusted all gaps to spec. & solved problem
Old Jun 4, 2003 | 01:25 AM
DaddyWags's Avatar
I have my CEL on too and pulling a 421 code and the engine is doing the same thing. I have header, test pipe and axle back. Reset it several times, but CEL comes back on. My car is a manual too, and just yesterday it started to idle funny. Gonna get my SAFC and tune the car and see what is going on.
Old Jun 4, 2003 | 01:29 AM
DaddyWags's Avatar
think code 421 means inproper heating of cat. WTF does that mean?
Old Jun 4, 2003 | 01:44 AM
ghostrider's Avatar
Running a header and test pipe will throw your CEL all day cuz the o2 sensors are picking up the same reading. You can get a CEL fix to remedy that situation.
Old Jun 4, 2003 | 10:11 AM
DaddyWags's Avatar
Ahh sweet, any place that you know of that I can get a hold of to help fix this?
Revoluzion
12
Jul 15, 2022 10:24 AM
delta6force94
Jan 20, 2016 05:43 AM
rjsdxm
Jan 3, 2013 11:58 AM
wrxedout
Jan 29, 2008 03:06 PM
