Oxygen sensors?
Old Jun 18, 2010 | 11:36 PM
03lances's Avatar
The second o2 sensor has to go after the cat otherwise its pointless to even install it. The ONLY thing that second o2 sensor is for is it moniters the efficiancy of the cat by verifying the reading of that 02 sensor is cleaner than the one off the header verifying the cat is doing its job. It has no application for the engine at all.
Old Jun 19, 2010 | 12:11 AM
eusgen's Avatar
Thanks, I was just making sure because im not a mechanic, just a home DIY'er lol.
Old Jun 19, 2010 | 12:49 AM
EVO3675's Avatar
22mm wrench to remove either,,if you have gutted cat or test pipe you will have to do the trick of using a set of spark plug anti fowlers ,one drilled out to allow the o2 to screw in it the second goes on thefirst and then reinstall the o2 this is for the second o2 only it makes it read-----^-----^------^ like it should with a functioning cat. the universal o2's work great .my primary got crappy after running vp blue at the track for several weekends.
Old Jun 19, 2010 | 08:05 AM
migs647's Avatar
Originally Posted by eusgen
Sorry to bring this old thread back to life, but im having similar issues, just not exactly ;-). My 02 Lancer OZ Rally has an aftermarket exhaust that came with the car, im ripping all of it out and replacing it with bolts ons. The only thing thats bothering me is that the o2 sensor under my car is BEFORE the cat, not after. This is what came with the car when i purchased it, my car is a theft recovery and i can tell its been rebuilt, the exhaust header is all rusted like it sat in a junkyard for 16 years. and the whole exhaust system after the down pipe is all welded together instead of bolts/gaskets.
I just purchased new header w/ downpipe, new catalytic converter and catback, but there are 3 holes for o2 sensors.
1st is the exhaust header
2nd is just before the cat on the downpipe
3rd is just after the cat
The parts do come with plugs tho in case the o2 sensors are not needed, etc. Im just wondering what exactly i do need.
Is it OK to install the new o2 sensor before the catalytic converter? or better to install it after the cat?
You're supposed to install the O2 Sensor AFTER the cat. The one right before the cat is for a wideband sensor.
Originally Posted by MrLam
I believe the sensors should be on the header and before/on the catalytic converter. Thats how it is for my car.
As I said above, the sensor is supposed to be after the cat.
The reason for the second sensor is to verify the cat is doing it's job. The first sensor reads the ERG, the second sensor reads the ERG, and then the ECU compares the two readings. If they are not significantly different it knows the cat is NOT doing it's job. Therefor if you put the second O2 sensor before the cat, the readings would be nearly identical.
Old Jun 19, 2010 | 08:24 AM
jwick76's Avatar
Originally Posted by Nicker09
I have a few questions if anyone can help.
1. Does anyone know where i can get the best price on Oxygen sensors i might need both and the dealer wants to charge me 230 for each?
2. Anyone know how i would go about getting to the one thats located under the car by the gas tank?.
3. Checkers carries the oxygen sensors and they have "Universal" oxygen sensors do you think these can be or are as good as the ones from the dealer?
Thanks for helping me out.
You can get the oem versions at advanced auto for around $80, $160 for the second I believe. At CAP the oem version of the first one was $120 for me. You can go with the universals, but they have shorter wiring so you have to cut and splice a good amount from your existing wiring and connector. Always use heat-shrink connectors for anything outside the car.
Never get **** from the dealer unless you absolutely have to. I'm still a little irritated that they have the nerve to charge $350 for a timing belt change, and the only extra thing they do is "inspect the condition" of everything else. You'd think they'd replace all your belts, tensioners, and pulleys for that amount!
22MM wrench or 7/8 will work, or an adjustable. You might not be able to get them off without heating them up with a torch, depending on whether they are original or aftermarket, and if anyone put anti-seize lubricant on the threading. DEFINITELY buy a $2 packet of this when you pick them up, saves you tons of headaches taking them off in the future.
Old Jun 19, 2010 | 02:32 PM
eusgen's Avatar
Ok, so unforunately the weather is against me for the next few weeks so I can't get under the car to inspect wtf is going on. All i know is there is one o2 sensor currently in the stock exhaust mani, and then one "wideband?" o2 sensor before the cat, and NOTHING after the cat. So what do I do when i install my new exhaust system.
Old Jun 24, 2010 | 07:59 AM
eusgen's Avatar
Listen, I do NOT have a stock exhaust, what im looking at under my car is one o2 sensor on the downpipe BEFORE the cat and nothing after it. Im worried about how to make everything work once I have replaced all the parts. Does that mean I should plug the o2 sensor hole in the new downpipe and place the o2 sensor in the plug after the cat? Currently my exhaust is welded crap and there is no option for a o2 sensor after the cat, no "bung" i guess. ?correct me?
Old Jun 24, 2010 | 10:26 AM
03lances's Avatar
I o2 bung in the downpipe is usually for a wideband o2 sensor. You should have 2 stock sensors, one in your stock manifold (unless thats gone too) and the other right after the cat. After you install the new part you should have one somewhere before the cat and another right after the cat
Old Jun 24, 2010 | 09:18 PM
eusgen's Avatar
I just found this after scouring the service manual, this is pretty much exactly what my setup looks like now, so i am pretty set on keeping it the same, the car ran good til the front o2 sensor went bad and then the cat shortly after(which was only 3 months old).
raidokoiv
Aug 24, 2019 12:07 PM
Brandisher
Apr 23, 2016 11:17 AM
MitsuSkot
Apr 9, 2016 05:39 PM
DaBaum
Apr 8, 2016 06:46 AM
