Gas mileage problems
Old Jul 30, 2007 | 08:35 PM
  #31
02-Lancer-Es's Avatar
okay , just found out how much mine waists , its 25mpg(city no hwy),, thats okay considering its already time for an oil change, tranny fluid flush, and heavy rims(17's)and sice our cars have a 13.2 gallon tank , im getting about 330 miles per tank(city)
Old Jul 30, 2007 | 08:48 PM
  #32
eehjay's Avatar
Originally Posted by JohnnyBoy427
Well my car is going at about 3100 at 70 so idk if they could be geared differently? there could be variables like hills. Im going to have to look into it.
i doubt they are geared differently, but the hill variable and such does make sense. i drive all flat though, there aren't really any inclines or declines. minus offramps, that is.
Old Jul 30, 2007 | 09:04 PM
  #33
JohnnyBoy427's Avatar
No sht? Our cars have 13.2 gallon tanks? I thought they were 12? WTF? lol
Yeah in my area its all hills.
Old Jul 30, 2007 | 09:09 PM
  #34
ambystom01's Avatar
Wow that's bad gas mileage. I was getting 28 MPG with my lancer and it was pretty damn modified. You're getting the same mileage as my WRX at the moment.
Old Jul 30, 2007 | 09:39 PM
  #35
yea i looked it up in www.edmunds.com
Old Jul 30, 2007 | 09:40 PM
  #36
yea it sux but i hope it gets better after an oil change and tranny flush
Old Jul 30, 2007 | 09:57 PM
  #37
coal's Avatar
How many miles do you have? Timing could be messed up. Try a fuel system cleaner, air filter could be causing restriction.
And dont forget to disengage the parking brake.
Old Jul 30, 2007 | 10:07 PM
  #38
i have 100k and yea the e-brake isn't on,lol , how can i check if its still on timing?? (my car is super quiet , no engine noise at all)and btw i already checked the timing belt, its like new
Old Jul 30, 2007 | 10:42 PM
  #39
coal's Avatar
It can be checked with a timing light. But it might be a better idea to run it in to a shop. They might be able to find another problem.
On aside note PCV could cause a drop in mileage.= change valve.
Sticky piston rings could cause a loss in compression.= Use engine flush.
Old Jul 30, 2007 | 10:43 PM
  #40
is there a way to see if everything lines up?? like the honda's?
Old Jul 30, 2007 | 10:58 PM
  #41
coal's Avatar
By lines up do you mean the timing? If the car sounds and runs smooth that is probally not the issue.
I think PCV, Air filter and fuel system cleaner are a starting point. If you purchased the car from new and this is the way it has been the whole time I dont see any changes in sight. If you got this used then it probally only needs a tune up.
Old Jul 30, 2007 | 11:02 PM
  #42
ive had it since 70k , already did iridium plugs, spark plug wires,coils,short ram intake and i already used sea foam, but wat i was thinking is that i need a tranny flush.Becuz it delays shifts and shifting is getting rougher
Old Jul 30, 2007 | 11:15 PM
  #43
coal's Avatar
I say go for it.
Old Jul 31, 2007 | 07:42 AM
  #44
ambystom01's Avatar
Could try sea foaming the engine and seeing if that helps.
Old Jul 31, 2007 | 04:23 PM
  #45
anyoneelse's Avatar
I have an 02 es stick, sri, throttle body coolant bypass, rrm piggy v2 on 89 oct. Right now im just barely over the half tank mark and ive done 195 miles, equal city and highway driving. ive been driving it easy usually shifting at 2.5k to see what my mileage is. I ll post my results when i fill up.
