trunk rattle w/ GTS sun n sound
Old Sep 21, 2007 | 10:35 AM
shinobee1's Avatar
I've noticed if when you're pumpin' the tunes at about 16 and above on the stereo and step out of the car there is this nasty rattling noise. Anyone else notice this?
It's not the license plate, it's coming from inside...
Someone suggested using spray foam to fix it.. Any other suggestions?
Old Sep 22, 2007 | 03:35 PM
GeeTeeEss's Avatar
Ugh I know, I hate that noise.
It could be spare tire related, such as the jack or tools, but I havn't looked.
Old Sep 22, 2007 | 04:05 PM
shinobee1's Avatar
I found out what it is!
If you look underneath the car behind the the drivers side rear tire there is this oval canister part that is bolted on one side to another part. It's rattling because only 1 side is bolted down and is vibrating.
Fix: I just put a piece of sponge between the two parts to prevent the rattle
Old Sep 22, 2007 | 04:21 PM
Blacksheepdj's Avatar
Without looking, I'm going to guess that it's a carbon canister.
Old Sep 22, 2007 | 04:22 PM
evo_soul's Avatar
I fetched myself a stick to brance the plastic frame to the trunk wall where the lights are.
If you notice if you push down on the sub enslosure it stops vibrating, the stick did a good job.
GOOD BOY
Old Sep 30, 2007 | 12:57 AM
CamShaft's Avatar
i would have thought it would have been the fabric mold on the inside of the trunk lid which is a little loose, not very well secured. I was going to put some dynamat inside that between the truck and the molding.
Anyways if you did fix it by doing that then great. I am too lazy to car what the outside sounds like although that rattle is stupid and annoying from the outside...makes it look like you have a cheap system/crappy install.
Old Oct 14, 2007 | 10:54 PM
gravvyboy's Avatar
GOOD BOY
What kind of "Stick?" I'm noticing the Sub being a major cause of the problem with it not being bolted too securely.
Old Oct 16, 2007 | 09:02 PM
WhiteGTS18's Avatar
mine has a horrible rattle from the outside with my aftermarket sub and im really hoping its just that canister but i know its more then that. i think its the heat shield above the exhaust and also the rear deck part behind the backseat rattles.
i think i will be sadly removing my sub soon tho for a rear strut bar so i can shave back off the 100 pounds it weighs and make my car handle nicer.
DjRags604
17
Jan 5, 2015 07:14 PM
Arsenal4Life
Jan 8, 2014 09:58 AM
00EvoX
May 1, 2010 10:45 PM
buffaluphagus
May 19, 2009 01:42 AM
avengerhed
Dec 14, 2005 07:58 AM
