AUX problem
Old Oct 28, 2007 | 10:05 AM
08blackgts's Avatar
AUX problem
some of the songs i play through my ipod on my "08 gts with sun and sound package are muffled and scratchy. I have songs on my ipod that are bought from itunes, burn from cds, and downloads. However, it is not just one kind of song that is sounding muffled and scratchy. It is not just downloaded songs, but also songs that have been bought on itunes as well. I have a Dynex adapter cord from Best Buy. Do I need to buy the ipod cable that is offered through the mitsubishi website, get a more expensive cable, or am I just out of luck?? Anyone else have this same problem?? Any suggestions are greatly appreciated. I want to use the 650w system to its full capacity.
Old Oct 28, 2007 | 10:11 AM
angryGTS's Avatar
maybe its the cable??
Old Oct 28, 2007 | 11:15 AM
Blacksheepdj's Avatar
What volume do you have your iPod set to? You need to set the iPod volume to somewhere between 50 and 75 percent (then use the car stereo to actually control the volume of the music you hear). Otherwise it distorts the signal. I had mine on 100% and everything sounded crappy until I figured out the problem.
Old Oct 28, 2007 | 03:18 PM
mos_skeeto's Avatar
go in your ipod and set volume limit to 75% as the above user stated. Anything above will get clipped.
Is your Dynex cable just a straight forward Y cable? If so it should be fine, don't get the Mitsu cable.
Old Oct 28, 2007 | 07:50 PM
ingballesteros's Avatar
I've the same "issue" but I'm using a cable connected by the dock port which splits to Audio RCA and S-Video. Some of the songs sound crappy, some other not. I'll try this, but I was in the understanding that using the Dock port, will use the "best" volume to transmit.
Old Oct 28, 2007 | 08:25 PM
akvvirus's Avatar
ya i have been having the same problem too, i even forked up the extra money for a monster cable, but didnt do anything. but i will try the volume thing. i also think that transmitting from the dock port gets the best sound too.
Old Oct 29, 2007 | 06:58 AM
RJRR's Avatar
I had the same problem when I first got the iPod Touch. Old iPod was adjusted to 75% volume and it sounded fine. When I first hooked up the Touch it was all distorted and sounded like crap. Finally remembered about the volume adjustment, changed it and it worked fine.
Old Oct 29, 2007 | 07:30 AM
eg6motion's Avatar
its the ipod, not the cable. Ipod's have very poor output onto other devices unless using the dock connector. If you have another mp3 player, try that, you should notice a big difference
Old Oct 31, 2007 | 07:48 PM
akvvirus's Avatar
what if we use an ipod power adaptor that has a headphone jack on it thus getting the sound out of the dock, has anybody tried one of those? i used to have one of those, but it was stolen out of my old truck, and was wondering, because i was thinking of getting another one (if it works).
Old Oct 31, 2007 | 11:42 PM
mos_skeeto's Avatar
I have 2 of them. Generally bad experiences. It's not the mitsu's fault since every car I've tried it in, anything plugged into the cig lighter will cause some static.
That said, I have 2 of these devices. A belkin one and another one i forgot the brand. Long story short, the belkin one is usable because it has a dial to adjust line out volume. If it's too loud, it distorts. If it's too soft you can hear lots of static. The belkin is usable because you can find an 'okay' grey area. The other plug I have sucks because it has two settings. Loud and soft. Loud makes the audio distorted and soft puts too much static through.
Now the alternative is to take the fuse out (aka disabling the charging mechanism). I found that using the dock connector without touching the charger gives the same audio quality as the headphone jack.
Old Nov 4, 2007 | 02:28 AM
akvvirus's Avatar
so what u r saying is that if i use my iPod with out the charger it will sound better, because the charger is what is cause all the interference? cause i get 2 types, 1. when i accelerate it causes a high pitch sound, and 2. a low hissing sound that comes and goes every once in awhile.
i will try using my iPod w/out the charger and see how that sounds and if it fixes any problems. if not i will look for that belkin one(im pretty sure thats the one i had before)
Old Nov 4, 2007 | 02:43 AM
M@verik's Avatar
I use the belkin one that recharges as well. Have no problem with it at all. Sounds great.
Old Nov 4, 2007 | 09:15 PM
akvvirus's Avatar
well i used my iPod with out the car charger and it sounds great now, just thought i would let everyone know.
