idle rpms are high after exiting highway
Old Nov 19, 2007 | 05:14 AM
rvk778's Avatar
I know this has been posted before, but wanted to let you guys know my dealer is replacing the throttle body to solve this high idle rpm issue. they said it's a known problem in the 2008's now.
if you are having this problem, I would let your dealer know about it, and have the throttle body replaced.
I'll let you know how it goes, should happen this week.
Old Nov 19, 2007 | 06:46 AM
jappaswat's Avatar
man ur dealership is too nice.
it's hard to get a dealership that actually helps.
fuz_dnz's Avatar
Mine idles high but I'm pretty sure it's the engine warming up. 5 minutes after i turn it on it's pretty constant at 1500 or something. Do your RPM's fluctuate when idle?
Old Nov 19, 2007 | 09:53 AM
rvk778's Avatar
idle high at start(normal for warming up) then goes down below 1000 rpm when idle after 2-3mins. the real problem seems to be:
even after the car is warmed up, exiting a highway rpms are above 2000 rpm
and
maybe unrelated, but when switch from say 1-2 rpm's go up even after i've taken my foot off the gas.
either way, ill let you guys know the results of the changed throttle body. i'm assuming if they are changing it, they found an issue.
Old Nov 19, 2007 | 09:54 AM
fatyin's Avatar
for me.... i've experimented it for mine..
it stays@1500 when starting from freezing temperature =.. then it will slow down by approx 100rmp increment... BUT, it doesnt goes up and down
Old Nov 19, 2007 | 07:38 PM
CamShaft's Avatar
check out this previous thread on this issue:
https://www.evolutionm.net/forums/sh...=298536&page=2
Old Nov 19, 2007 | 07:51 PM
evo_soul's Avatar
if your car is idling at above 1200RPM something is wrong. Mivec has a idle stabilization feature to it in our 4b11. something is out of spec. "At idle, valve overlap is eliminated to stabilize combustion"
In other words at 0 speed ECU logic dictates for the above parameter to kick in. its not currently.
I am refering to a hot engine, such as the exiting the highway.
cold engine is a different story
Boombox
32
Jan 23, 2016 02:34 AM
ron2003
Aug 5, 2011 10:19 PM
aosal
Lancer Troubleshooting
Apr 16, 2011 04:50 PM
polish_pounder
Mar 21, 2011 08:01 PM
EvoG8r
15
May 11, 2005 06:36 AM
