vibrating/out of round issue
Old Dec 18, 2007 | 09:48 AM
booboo0187's Avatar
vibrating issue
so i don't really know what to make of this. if i should be concerned or not even worry about it. i use my manual 06 oz as my daily driving car. sometimes when i accelerate fast(anywhere between 5000 and 6000 rpms) i notice that my car shakes/vibrates. not a tremendous amount but enough to put me in question. last week when i sped on this one occasion it shook a lot when i was in 2nd gear. from my experience with this issue i don't think it could be an unbalanced tire because it doesn't happen consistently. i also don't think it has to do with any certain gear i'm in because every now and then the car with shake a bit while i'm in say 4th or 5th just coasting at low rpms. my one guess is it's due to the fact that i don't shift perfectly smooth every time, but the vibration continues for longer than i feel it should. so....
Old Dec 18, 2007 | 09:54 AM
slipshft's Avatar
What is the speed? Around 55-60MPH? I had this same problem after I had a flat. I thought it was a balance issue, but found that the wheel wasn't seated properly when it was put back on.
However do not rule out a balance issue. I took mine to wally world, and they checked it for cheap.
Old Dec 18, 2007 | 12:51 PM
booboo0187's Avatar
the speed is irrelevant. it has happened at various speeds. plus there was only one time that it was real bad, the other times it's close to unnoticeable, but i do notice it. and someone else in my car noticed it too. if it actually was a balance issue, wouldn't the problem be consistent and not periodic?
Old Dec 18, 2007 | 12:53 PM
jakermeister's Avatar
Check your tire pressure first.
Old Dec 18, 2007 | 01:22 PM
booboo0187's Avatar
good idea, you don't think it would have to do with engine mounts at all do you?
Old Dec 18, 2007 | 01:52 PM
SLVROZ_03's Avatar
Check your CV boots for rips...
Old Dec 21, 2007 | 10:33 PM
booboo0187's Avatar
ok, i checked the pressure in my tires and the rear right tire was only at about 12 psi while all the others were at 26/27 psi. so i filled them all to about 32 psi. i havent gotten a chance to check the cv boots, but until then i'll be waiting to see if it still vibrates.
Old Dec 21, 2007 | 11:54 PM
DemisedGabe's Avatar
bearings?
KenyonKanye
Jul 19, 2013 06:45 PM
PaulyX
Jun 26, 2013 01:54 PM
gypsy
13
Mar 14, 2012 05:05 PM
rcheung
22
Jul 21, 2008 07:34 PM
sdfontanini
Jan 29, 2008 03:34 PM
