New bored throttle horrible shifts
I bougth a bored throttle from around here no biggy to install but since the troter is installed my AT transmission now shifts 10 miles before the shift is supposed to happen and when you release the gas pedal and stop instead of going in neutral the car downshifts sometime making hard stops. all and all the shift are very messed up Does any one knows how to fix it any ideas would be appreciated.
I bought it used from some one i guess that the trotter sensor is installed wrong since i changed the ones it had for mine because it had the MT sensors but there is no other way to install the sensor so i cant figure out if its not placed well. Installing the trotter is no rocket science 4 screws and plugs so there is little room for errors to occur.
i might as well reset the ECU I was avoiding it because the piggy starts gobbling gas after reset for a while.
RuckerPark
43
Jul 28, 2008 06:01 PM
